Powertap Pro+ 2012. 11 speed conversion possible ?
I searched for this subject, but didn't find anything substantial.
I know there are a lot of wheel building wizards here.
So I'm asking if anybody successfully converted a 2012 Powertap Pro+ to be 11 speed compatible.
I'm opened to solutions....
Thanks
Louis
Thanks
Louis
Yes, I forgot to specify it's the SRam/Shimano freehub 10S.
A Campy conversion would be very costly (2 bikes, 3-4 rear wheels) .
I'm pretty shure (although not certain) the new Pro version freehub body (11s compatible) doesn't fit the older hubshell...
Louis
Louis
- jekyll man
Louis-
he just means buy 1 campag freehub body, and 1 campag 11 cassette.
so long as you pick one for a 15mm axle
This will work fine on 11 spd shimano.
No need to change all bikes; after all you can only ride the wheel on 1 bike at a time
Official cafe stop tester
Yeah, I just found out about this (12mm older axle models VS 15 mm ones) after further search.
Just hope the (already bought and in the mail) hub axle is a 15mm one...
The seller didn't know that detail, although he told me the hub was a 2012 one...
Louis
Louis
- jekyll man
think they changed 2008 or 2009 so you should be alright
