It is currently Tue Jan 17, 2017 10:36 pm
Post new topic  Reply to topic  [ 15 posts ]
 Post subject: TB14 Rims & 27mm Tyres
PostPosted: Sun Aug 17, 2014 10:31 pm
Has anyone fitted Vittoria Open Pave 27mm or Challenge Paris Roubaix 27mm tyres to H Plus Son TB14 rims? I need to know how it affects the section of the tyre. TIA
PostPosted: Mon Aug 18, 2014 7:55 am
Tinker, Taylor, Tart
Compared to a standard (19mm) width rim it will make the tyre circa 2mm more rounded on each side.
Your question is far from clear, FWIW. All the wider rim will achieve is a more rounded tyre profile. As long as your frame and brake calipers have clearance for the (comparatively) big tyre, you're ready to rock.
I haven't run a 27c, but a 26c Grand Bois Blue Cerf felt pretty good for a clincher.
PostPosted: Mon Aug 18, 2014 8:37 am
Sorry. I'm changing rims from Ambrosio Giro d'Italia to TB14.
Are you saying the tyre will be 1mm larger in radius from the centre? Thanks
PostPosted: Mon Aug 18, 2014 8:58 am
Not so much in the centre - if anything it will be slightly lower in the centre than on a narrower rim. The width of the rim will pull the tyre into more of a uniform round shape from rim edge to rim edge (across the tyre), Vs a more bulbous round shape on a narrower rim.
This image sort of explains it:
PostPosted: Thu Aug 21, 2014 6:49 am
Thanks man. They grew 3mm wider with the change of rims so still fit my Stainless which was built with 27s in mind but not the carbon :(
PostPosted: Thu Aug 21, 2014 6:59 am
That's awesome. Love it.
PostPosted: Fri Aug 22, 2014 1:17 pm
Stem has to be swapped back to DMP as pearl isn't a perfect match. Should have had it painted at the same time as the frame. Bugger!
PostPosted: Fri Aug 22, 2014 9:36 pm
The TB14 has the same internal width as the archetype. On the archetype the 27mm Pave tyre is 27mm. On a 15mm internal width rim the 27mm Pave is 25mm, so you get cheated a bit.
www.thecycleclinic.co.uk
PostPosted: Fri Aug 22, 2014 10:40 pm
I am fairly sure the Paves were wider than that on my Open Pro Wheelset -- 26ish. We're talking about the Vittorias, right?
PostPosted: Sat Aug 23, 2014 9:33 pm
Yes vittoria's there is only one PAve I know off. Still 27mm on a wide rim, I was hoping for more!
PostPosted: Sun Aug 24, 2014 9:18 pm
Sorry to go off topic, but I was wondering if any of you had trouble mounting tires on these rims? I've used veloflex, vredstein and vittoria and none of them went on without a serious amount of effort (and broken tire levers)
PostPosted: Sun Aug 24, 2014 9:24 pm
No problem at all. When I was using Ambrosio Giro d'Italia rims it was another matter!
PostPosted: Mon Aug 25, 2014 8:48 am
As a side note think challenge say the PR open tubular isn't compatible with the TB14 or any wide rim
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Mon Aug 25, 2014 9:09 am
Do they? If you check the chart they have on their site they actually only advise against going outside the ETRTO standards for tyre width.
The measurement you need to be looking at is the internal width of the rim, TB14's come in at 17.5mm, so there should be no issue with these tyres.
PostPosted: Tue Aug 26, 2014 9:28 pm
No problems mounting any tyre on H plus son rims. Tyre levers should not be needed.
There are no new unread posts for this topic. 27mm or 25mm rim width, which is better?
in Everything wheels
dannyboybad
27
1900
Tue Nov 08, 2016 9:46 pm
Patb095 View the latest post
There are no new unread posts for this topic. Attachment(s) 29er Carbon Rims with Extralite hubs and Xentis rims, 1238 g
zzeuzz
Tue Dec 06, 2016 9:13 am
zzeuzz View the latest post
There are no new unread posts for this topic. Tire size and aero rims: how almost every clincher user defeats the purpose of aero rims
nemeseri
38
3397
Fri Sep 02, 2016 6:59 pm
nemeseri View the latest post
There are no new unread posts for this topic. Tyres for Zipp 404? 23/25c?
[ Go to page: 1 2 3 4 ]
PLuKE
45
3124
Wed Nov 02, 2016 1:48 am
ProfessorChaos View the latest post
There are no new unread posts for this topic. the weight of air in our tyres
Delorre
12
1588
Sun Jan 08, 2017 2:10 pm
wingguy View the latest post
Users browsing this forum: punk and 4 guests
