Titanium external cam skewers
refthimos
by refthimos
I know I might get my WW card revoked for saying this, but I no longer ride ti skewers - I want my wheels as stiff as possible, and I want my wheels clamped down as securely as possible. So all I use now are DT Swiss RWS skewers - steel with aluminum lever. Front weighs 51g and rear comes in at 55g. Nothing clamps as strongly as these suckers.
EVO Hi-Mod | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 3/5
P5 | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 7
T1 | Power2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
SuperX Hi-Mod Disc | Sram Red | Power2Max NG
VTBike
by VTBike
I'm using Tune Dc-14's and love them. I'm 200 lbs, ride out of the saddle often, and am on non-stop large hills here in VT. The only issue I have is that I need to make sure the rear wheel is tight in the drop-out before every ride. On a couple rare occasions, the rear wheel has shifted ever so slightly - just enough for me to notice a decrease in shifting crispness. But checking the QR before every ride is no big deal to me. I feel no real flex; and certainly I'm not having the wheels rub the brakes at any point in time. Unlike other super lightweight QR's which you may have to be careful with the amount of force you clamp down with - Tune states in the instructions that you may clamp down as hard as your heart desires - and that the skewer can take it..!
saroadie
by saroadie
I've found a happy "middle ground" with Tune AC14 skewers. At 48g you're only taking a tiny 15g hit over the DC14s but gaining an internal cam clamping mechanism (like Shimano/Campy) which holds the wheels in very securely. I am 220lb and race and train on these with no issues.
IME the internal clamping mechanism is much more reliable and consistent than the external mechanism of the POP or tune DC14. I broke a POP external clamp trying to get decent clamping force. No issues with the AC14, over 10000km trouble free. The wheels never move no matter how hard I ride/corner. As VTBike indicates, I too noticed the rear wheel could move slightly sometimes when using external mechanism shewers. With the AC14s, the clamping force is maintained until you release it. I have checked many times and there is no loss of force with use.
"Bite off more than you can chew, then chew like hell." Peter Brock.
rustychain
by rustychain
Even at my weight I have had no issues for the last 5 years using skewers as light as 48 grams for the pair. They are perhaps a bit more fussy in use. These days I mostly just use the Campy skewers, my average speed has not gone down BTW :shock:
WW Velocipedist Gargantuan
NiFTY
by NiFTY
So are people complaining about the cam design of lightweight skewers causing the rear wheel to move relative to the dropout under load or flex in the ti axle causing the wheel to move relative to the dropout under load?
LionelB
by LionelB
Campy skewers for me too. I like a solid connection in that spot.
runningrunningjump
by runningrunningjump
I've run most decent QRs. never had any problems.
I currently have a pair of mt zoom ti and a pair of kcnc ti on road and MTb and had no problems at all. If the QR doesn't have a cam, then you need to tighten them up a little more.
Really quite supprised there is some much negative about light QR, unless in general either I always do my QRs up too tight, or those that have experienced problems have in general not been doing theirs up enough.....
Horizons
by Horizons
I wanted to order some titanium ENVE skewers (steel is not available), but after reading something about titanium rods stretching very easily and external cam skewers not clamping as good as internal ones.. are 'fancy' skewers worth it? or should i just check my lbs for some Shimano skewers which have always worked fine. Zipp (steel) skewers are easily available as well but are external.
Couldn't find any threat regarding this.
eric
by eric
Depends on your needs. And on the skewers. I have used both internal and external cam skewers that did not work very well. But the external cam design tends to make skewers that don't clamp as well as internal cam.
I've not noticed any of my Ti skewers stretching.
I've had good luck with Kcnc Ti external cam skewers. But the levers on those are short so you need to keep that in mind and really crank them down. I've also had some Chinese external cam Ti skewers work well... and some not so well.
But if it's not a WW bike, Dura Ace skewers are the gold standard. Heavier than the WW skewers but they do clamp well.
kode54
by kode54
i have Enve skewers on both bikes with no noticeable stretching on titanium rods. besides, i take my wheel off and on all the time and readjust tightness then, so no issues.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
