It is currently Mon Feb 20, 2017 12:38 pm
PostPosted: Tue Aug 12, 2014 12:28 pm
I currently use Vittoria Corsa CX, but I know they are not the fastest tub for race day. I was looking at the Crono or the Conti Podium TT.
Just wondered if anyone has experience of these tubs or can recommend a good race day alternative.
PostPosted: Tue Aug 12, 2014 1:11 pm
The CX test fast very often (though there seem to be outliers when tested by a german mag). Certainly faster than the Podium. See here, although it's about older versions of the tyre viewtopic.php?f=3&t=114537 .
Facing the same question at the moment, running 22mm SCs, pondering to glue up 25mm SC or CX for a TT, at least for the rear.
Edit: here's another thread with some info viewtopic.php?f=3&t=116471
PostPosted: Tue Aug 12, 2014 3:16 pm
Podiums never seemed quick for me but they are fairly bullet proof.
Gone through a few corsa cx's fairly quickly, but now on Schwalbe TT's. Not had long enough to give a proper evaluation though.
Not sure if you're planning on using a disc wheel, but you might encounter problems with the new corsa valves.
Official cafe stop tester
PostPosted: Thu Aug 14, 2014 2:24 am
Veloflex Record
Vittoria Crono - 19mm @ 145psi (ish) or 24mm@20 psi less
See : viewtopic.php?f=113&t=127181&p=1086740#p1086740
PostPosted: Fri Aug 22, 2014 10:02 pm
How about a tyre that is not likely to puncture. Nothing ruins a TT like a puncture and nothing makes you slower either. I'd stick with the corsa's.
www.thecycleclinic.co.uk
PostPosted: Sun Aug 24, 2014 1:49 pm
the latest science shows that you should match the tyre width closely with your rim width.
PostPosted: Sun Aug 24, 2014 4:54 pm
well that has always been true and is rather obvious how it has taken so long for everyone to realise including me I don't know. given most tubular rims are 20 or 21mm width it does mean narrow tubs like people had back in the 80's and 90's.
PostPosted: Mon Aug 25, 2014 2:49 am
Other than in a stage race, we go on the edge. A flat, ends the TT. But the TT is for you, or if its a race for position, its hard to remember who got 2nd.
There are no new unread posts for this topic. Had enough of Garmin - recommend me something simple
solarider
35
2712
Sun Jul 17, 2016 8:22 am
reknop View the latest post
There are no new unread posts for this topic. recommend a traveling pump
dgasmd
23
1530
Wed Nov 30, 2016 2:35 am
Butcher View the latest post
There are no new unread posts for this topic. Recommend a 160mm crank
stripes
Sat Feb 04, 2017 7:03 pm
stripes View the latest post
There are no new unread posts for this topic. Recommend a bottom bracket for BBright
stripes
11
799
Wed Jan 18, 2017 6:10 pm
1415chris View the latest post
There are no new unread posts for this topic. What crankset would you recommend for SRAM etap
perwjensen
14
1322
Mon Aug 22, 2016 2:23 pm
DavidMLee View the latest post
Users browsing this forum: No registered users and 7 guests
