It is currently Sat Aug 19, 2017 12:42 am
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sat Aug 09, 2014 6:19 pm
Just about to pull the plug on some boras. As these have a narrower rim than some of the newer wheels am I ok to use 25 tyres?
Thanks.
made thread title more descriptive
 Post subject: Re: Campagnolo Boras
PostPosted: Sat Aug 09, 2014 6:23 pm
You're okay but that's not the best setup in the front. #drag. Put a 23 on the front and keep the 25's for the rear.
Sent from my Galaxy Nexus using Tapatalk
PostPosted: Sat Aug 09, 2014 7:05 pm
I'm running 25's on my Boras, both front and rear. Much prefer the added stability using a 25 up front vs a 23. However, if you're buying new and given that new Boras are just around the corner, I'd probably wait for the new ones which will be a little wider with a rim bed that will fit the 25's, or bigger, a bit better. And maybe even be a little more stable, don't know. The only thing about running 25's on the current Boras I find is that when my brakes are where I like them and the tires are inflated, it's a squeeze to get the tires out even with the calipers released (Campagnolo). But no big deal. I guess if you're getting a screamin deal on a set of current Boras then fine, as long as you know there's new ones coming soon. Nothing worse than buying something that you think is current only to find out a week later that a new model is already being released. Either way, I'm sure you'll like them.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Sat Aug 09, 2014 8:41 pm
Thanks for the help.
I'm buying a used set as this is my first go at seeing how I get on with tubulars. This way I'm only going to be spending £550.
PostPosted: Sun Aug 10, 2014 3:11 am
At a set of used boras at that price sounds like a steal, I'll go for it and not think too much about the upcoming one. I'll go for 23 in front and 25 behind though for the aero benefit, since tubulars will give you a plush enough ride already.
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Sun Aug 10, 2014 6:00 am
25 are not a problem on boras.
PostPosted: Sun Aug 10, 2014 3:47 pm
550 for a set of Boras is a super price.
You will love tubular and i think 23front and 25 on the rear wheel will be more than ok...
Enjoy them
PostPosted: Mon Aug 11, 2014 11:00 am
Shop Owner / Manufacturer
I suspect this may not be true but it's an un-provable hypothesis wither way as it depends on how you are defining "aero".
Wider tyres are only *more aero* (whatever that actually means in the real world) as an interactive component with a suitably shaped rim, according to all of the data that I have reviewed.
The problem is that we don't have a standard definition for "more aero" or even "less aero" - we don't have parameters for the frame, wheels, legs or any other part of the rider-wheel system standardised, we don't have a standard set of yaw angles or air speeds and last we don't have standard cadence rate for our yet to be defined legs making a mess of that unknown airspeed and it's un-defined yaw angle. And for uncertainty factors in trying to produce an accurate, meaningful, quantitative measurement, that is just for starters ...
In a wind tunnel, in a non-revolving test factoring all of the above out, it'll still depend on the precise rim shape and I have never seen that data for a Campagnolo Bora in public-land - not that I have looked that hard because it would be real-world irrelevant anyway (with apologies to all the would-be aerodynamics weenies out there ...)
PostPosted: Mon Aug 11, 2014 8:23 pm
Thanks everyone for all your help. I'm picking the boras up in a few weeks.
PostPosted: Tue Aug 12, 2014 4:35 pm
Bora Ones or Ultras/Ultra Twos? Great price whatever.
PostPosted: Tue Aug 12, 2014 8:35 pm
They're the Bora one's
There are no new unread posts for this topic. Attachment(s) What bikes look good in 'bigger' sizes?
[ Go to page: 1 2 3 4 5 ]
jmaccyd
62
5904
Sun Jan 01, 2017 10:39 am
L3X View the latest post
There are no new unread posts for this topic. Shimano S-Phyre Half Sizes
Winston
Fri May 19, 2017 2:34 am
3Pio View the latest post
There are no new unread posts for this topic. Parlee Altum owners- Let's Talk tire sizes
boots2000
23
1785
Mon Feb 27, 2017 10:58 pm
RichTheRoadie View the latest post
There are no new unread posts for this topic. Setting up a smart trainer for an older couple - 1 bike for two different sizes?
in Training
Shrike
Tue Mar 07, 2017 9:47 am
Shrike View the latest post
There are no new unread posts for this topic. Campagnolo Bora Ultra 50 tubular rear wheel only, Campagnolo freehub body
in Wanted
clm2206
Mon Jun 12, 2017 5:22 pm
clm2206 View the latest post
Users browsing this forum: No registered users and 4 guests
