Aluminium tubular wheelsets - Reasonably light and durable
- ultimobici
- in the industry
- Contact:
Has anyone got some suggestions for wider alloy tub rims?
I'm using H Plus Son TB14 clinchers and want a tub wheelset that won't require brake adjustment every time I change them over.
Using 25mm and perhaps 27mm tubs.
Have looked at Major Toms and TB25s. Is there anything else or would you not bother?
- in the industry
- Contact:
HED belgium C2 as well here. I have a set 28H on record hubs built with CX-ray spokes, they are very stiff and very pretty weight is ust under 1600g I think. 22mm tubs are too narrow for them but I did fit a spare 22mm gator skin tub while out a about and it was secure, left it on for a few rides till I fitted a new 25mm competition. 25mm tubs fits perfectly and it is what I am using.
What is the TB-20 rim? is it another kinlin rim?
Velocity Major tom is another alternative but I am not sure the shape of the well is best suited to tubs less than 27mm wide. Ambrosio rims are 21mm wide so not much adjustment will be needed.
- ultimobici
- in the industry
- Contact:
Already have GL330s and if they are changed it'll be to Ambrosio Crono F20 or similar. Mavic NOS rims command a ridiculous price compared to modern rims. As for modern Mavic rims, I wouldn't touch em with a barge pole.
- ultimobici
- in the industry
- Contact:
If I was paying retail it'd be different. Being in the trade brand new Cronos are not that much more!
- in the industry
- Contact:
The chrono though is quite a flexible rim as it is very light. I am hoping the GP4's are a fair bit stiffer. For me personally I would not ride a chrono rim on the rear wheels as I would break it.
I have a set of HED C2 laced to Alchemy Elf/Orc. Tremendous wheel. I've found a nice sweet spot with 25mm tires, although I have not attempted anything larger.
"Deserve's got nothing to do with it." William Munny
- ultimobici
- in the industry
- Contact:
bm0p700f wrote:The chrono though is quite a flexible rim as it is very light. I am hoping the GP4's are a fair bit stiffer. For me personally I would not ride a chrono rim on the rear wheels as I would break it.
How much do you weigh?
Ambrosio Montreal are cheap, durable and look classy but not that light (470gr each).
http://www.ambrosiospa.com/index.php/pr ... a-tubolari
TB20 is a Kinlin Rim. I̶ ̶b̶e̶l̶i̶e̶v̶e̶ ̶t̶h̶e̶y̶ ̶w̶e̶r̶e̶ ̶b̶e̶f̶o̶r̶e̶ ̶t̶h̶e̶ ̶T̶B̶2̶5̶. 23mm outside width and 22 deep. Mine came in at 401g and 398g
They were $62 for the pair shipped. We will see if they are any good.
corrected
corrected
drider85 wrote:TB20 is a Kinlin Rim. I believe they were before the TB25. 23mm outside width and 22 deep instead of 25. Mine came in at 401g and 398g
Any update yet ?
