It is currently Wed Jan 24, 2018 6:57 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
 Post subject: Winter wheel question
PostPosted: Sun Aug 03, 2014 7:06 pm
So am looking at winter wheels as I don't want to run my 202s in the bad weather.
My question is do I go aluminium tubular, tubless or back to clinchers?
The tubless versions are a concern as I don't think there are any "good" tubeless tyres that are designed for winter use. Therefore is it clinchers or do I run arenbergs over winter?
I ride in the UK on the lovely pot holed roads of surrey if that is of any bearing.
PostPosted: Sun Aug 03, 2014 7:31 pm
Shimano DA C24 wheels are you friend - summer or winter - smooth or pot hole infested roads - flat or mountain terrain. They roll so nice and unaffected by weight or tire choice. Clinchers are the ones to get since changing a tire is a piece of cake - even in winter when your hands are cold. You don't even need tire tools - just your hands are sufficient.
PostPosted: Sun Aug 03, 2014 7:43 pm
PostPosted: Mon Aug 04, 2014 5:54 am
^ Agree that the C24's are nice. Another good option is to go for wide rims and run 25-28mm tyres, thinking of the Pacenti sl23, HED etc. Clinchers are always funner in winter when tyres start acting like magnets to sharp things.
Norwood & Adelaide Uni CC
PostPosted: Mon Aug 04, 2014 9:07 am
Have you looked at what Wheelsmith has to offer? Race24 or so? Would probably be my first choice. Or maybe just Archetype rims (Velocity A23, or any other 23mm rim you can get at a fair price) on Shimano 105 (or Ultegra, if you want 11 speed) hubs. You asked for winter wheels after all.
PostPosted: Mon Aug 04, 2014 10:07 am
What he said. ^^^^^
Handbuilt on hubs to match the bike/drivetrain.
Sensible rims, sensible lacing, sensible spokes. Then if you have an issue/need a new spoke/buckle the wheel/dent the rim/wear out the braking surface you can get parts anywhere in 24 hours, and shops across the country/europe/globe will be familiar with the construction.
C24s might be lovely, but when Mr Shimano goes from 20 to 21 spokes, or launches the new C24.1, parts availability will drop very quickly, in some cases a snapped spoke could write the wheel off.
If you are likely to service them, cup and cone will give you a longer hub life (several years with half an hours tlc once a year) if you want fit and forget/hose down and stick in the garage after every ride, get cartridge bearings and take them to the shop every two or three years for new bearings. (Hope for instance)
PostPosted: Mon Aug 04, 2014 5:48 pm
One thing I have looked at is some Nemesis rims on hope hubs
PostPosted: Mon Aug 04, 2014 7:10 pm
C24s have thin brake tracks - not the best for longevity.
Pacenti SL23 hand builts with a hub of choice would be nice - wider rim means more volume, and more comfort at lower pressures.
As for tubeless tires, I had good luck with Hutchinson Secteur 28mms for a bad weather/road tire.
PostPosted: Tue Aug 05, 2014 2:51 am
My preference would be some HED Belgium tubulars with a strong tubular tire and some OrangeSeal inside. Hub is your choice (I'm partial to DA or DT 240 personally) but a 28/28, 28/32, or 32/32 build depending on your size.
Gaulzetti Cabron Disc = (weight unknown)
Rock Lobster Team Tig SL Disc = (pending)
Sold: Ridley X-Night Disc = 7.80 kg | Ridley Noah FAST = 6.86 | Ridley Fenix = 6.74 | Raleigh HiLife = 7.46 | Fuji SST = 7.34 | Van Dessel FTB = 7.58
PostPosted: Tue Aug 05, 2014 5:07 am
I'm 64kg and it's a sub 7kg bike. Roads can be rough and I will use them on cobbles if that makes a difference
PostPosted: Wed Aug 06, 2014 8:53 am
Winter wheels which need to be tough for cobbles I'd be looking at good hubs (Shimano or Hope etc) and a reasonably light rim with plenty of spokes and a 25mm tyre profile.
The Velocity A23 or the Ambrosio Nemisis would do very well. Shimano RS80's would also work pretty well (cheaper option than DA so you don't mind destroying them) but I always found the low spoke count led to brake rub and me not being all that happy with the wheels going through pot holes (which as you'll know have been so numerous that you can't miss them all in Surrey over the last couple of winters).
PostPosted: Wed Aug 06, 2014 12:37 pm
Either buy something dirt cheap (RS10, R7 etc) and ride into the ground, or get some reasonable quality hubs and archetype rims (or similar), and replace the rims when they wear out.
Don't want anything with a highly polished finish or the salt will just eat it away unless you are meticulous with washing your bike immediately after every ride..
Official cafe stop tester
PostPosted: Thu Aug 07, 2014 2:01 pm
Aluminum clinchers for winter wheels always. You can find great deals on craigslist if you are patient. Picked up some fulcrum 3.5 that someone pulled off a new cervelo for $150.
PostPosted: Fri Aug 08, 2014 3:52 pm
I agree with Jekyll,
Go cheep and use the crap out of them or build what you need from good components.
Might not be bullet proof but zipp 101s have a similar profile to the 202s and are alum clinchers. I've had good luck with mine.
Using Tapatalk
PostPosted: Fri Aug 08, 2014 7:09 pm
You would not want to ride C24' in an english winter as you would wear the rims out. 3000 mile of wet weather riding has worn my DT Swiss RR415's out annoyed at that but nor surprised as last winter was filthy in the extreme. these are £50 rims not several £100's as for C24's.
So my veiw is some handbuilts with a a velocity A23 or archetype rim as the are not too expensive when they wear out which the will.
www.thecycleclinic.co.uk
There are no new unread posts for this topic. Winter training question
in Training
cho00010
Tue Sep 26, 2017 11:26 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Question for wheel builders...
in Everything wheels
addictR1
23
1621
Sun Feb 19, 2017 8:56 am
Marin View the latest post
There are no new unread posts for this topic. PRO 3 Spoke - Ultegra - Carbon Front Wheel -> Track or Road wheel ?
Tillquist
Fri Oct 06, 2017 6:18 am
F45 View the latest post
There are no new unread posts for this topic. Winter Project
Ellipsis415
Sun Nov 19, 2017 11:02 am
bikewithnoname View the latest post
There are no new unread posts for this topic. new tub wheels for the winter grind
sungod
Sat Sep 16, 2017 10:32 pm
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 3 guests
