Disc brake wheels
bm0p700f
by bm0p700f
DT Swiss 240 centrelock straight pull hubs are 356g/pair that to me is best disc brake hubs on the market. Durable and quite light, pricey but you get what you pay for.
Tamu8104
by Tamu8104
Finished another disc wheelset. LB 27mm wide tubular rims laced to DT 240 hubs with Sapim Laser spokes. 1319g for the set.
Gaulzetti Cabron Disc = (weight unknown)
Rock Lobster Team Tig SL Disc = (pending)
Sold: Ridley X-Night Disc = 7.80 kg | Ridley Noah FAST = 6.86 | Ridley Fenix = 6.74 | Raleigh HiLife = 7.46 | Fuji SST = 7.34 | Van Dessel FTB = 7.58
bm0p700f
by bm0p700f
Are those the light bicycle rims? I have them too but I used the cheaper Miche 966 hubs 28H and they came in at 1419. Best thing is I can fit MTB 29er tubs or wide road tubs. I will use them on my MTB but I might do another set for a forthcoming road bike.
Tamu8104
by Tamu8104
Yes, the are the LightBike rims. I'm trying to decide if I build another set for the MTB but I'm thinking I may go tubeless on that build.
mentok
by mentok
bm0p700f wrote:Are those the light bicycle rims? I have them too but I used the cheaper Miche 966 hubs 28H and they came in at 1419. Best thing is I can fit MTB 29er tubs or wide road tubs. I will use them on my MTB but I might do another set for a forthcoming road bike.
this was going to be my first question - what's the profile like for gluing a big 50-55mm tyre?
Tamu8104
by Tamu8104
@mentok
I'm not sure if I completely understand your question but I'll give it a shot and you can tell me if I'm off. The rim is 27mm wide so it has a large glueing surface. I wouldn't put anything skinnier than the 27 FMB that I currently have on there.
The other issue you need to consider is how wide the base tape is on your tubular. Wider tubular rims can help create a wider contact point with the base tape and can help prevent a rim from rolling off. I don't see much of any difference in "shape" of the tire on wider tubulars like I see with wider clincher rims. You may feel a difference in cornering because of how the sidewall interacts with a wider rim behind it.
bm0p700f
by bm0p700f
29er tubs fitted like a dream mine are 51mm wide. The shape seems perfect for 27mm FMB or Pave's e.t.c. Wide tubular rims with wide road tubs should be a bit more aero is the width match, given I like wide tubulars I think this is the way I will go for a road disc brake build.
