Cane Creek Crono Hub
cajer
by cajer
I have a pair of cane creek crono hubs (the ones that have nipples at the hub) that I really like. However the rims on them are competely worn down, and I would like to build the hubs into a pair of Flo 30 rims for training wheels.
Would it be possible to lace them normally with the nail head end of straight pull spokes at the hub and nipples at the rim? I'm just worried that the hub might not be strong enough or designed for straight pull nail head at the hub.
Stefano
by Stefano
I think unless the nipples are realllllly small, you're gonna have trouble doing it that way. Seems to me that it would be easier if you ordered some Chinese carbon rims drilled for internal nipples and then just laced it with the head at the rim like it was designed for. Maybe put a washer in there or somn so it doesn't dig into the carbon.
If you're stuck on the flo 30s, id just get new hubs.
Stefano
cajer
by cajer
As you saying that the holes for the nipple assembly at the hub might be too big to take just the nail head of the spoke?
Stefano
by Stefano
Yes, that is what I am saying. To properly support a straight pull spoke, the hole has to be around the outside diameter of the spoke- so 2.0mm at most, or else the head of the spoke could pull off. Most nipple holes are at least 3mm, which might actually be bigger than the entire head of the spoke. Maybe if you did some modifications with thick washers at the hub or something you could get it to work.
cajer
by cajer
Well I guess it's time for me to take apart my current wheel and see
ergott
by ergott
Don't bother. Won't work. Honestly, those hubs are mediocre quality and really heavy anyway. Better off with new hubs. I swapped those hubs out of wheels before and had them in my hands. Nothing special save for looks.
The only way to actually reuse those hubs to a different rim is to cut the ends of the spokes off and thread them so you have threads on both sides. It's easy if you have access to a Phil Wood or similar spoke machine. Then threadlock one end with the proper nipple. Finish off the build as you would any other wheel.
F45
by F45
Yes, it's possible, but you will need to use steel washers or spacers at the hub side to mimic the way the nipples sat in the flanges.
kramnnim
by kramnnim
I guess the holes might be larger than they need to be, but it looks like the nipples/nuts don't actually go in to the flange, but are like the internal nipple rims suggested above...?
Random picture from Bing- http://content.mtbr.com/images/Tradesho ... dimg12.jpg
ergott
by ergott
That's why I suggest using a spoke that is threaded on both ends. Lock the nipples at the hub because adjusting them sucks. Much easier at the rim.
Anyone with access to a Phil Wood or similar can do this.
cajer
by cajer
I think I'll try the washers at the hub and see if I can build up a wheel when my Flo 30 rim gets in.
ergott
by ergott
What washers? They don't make washers designed for this. Are you going to get custom washers?
Last time. Please don't use washers. It's not the right way to do it. As it is you are taking a mediocre hub and lacing it up to some nice rims. At least use the correct spoke attachment method.
I'm out.
kramnnim
by kramnnim
...are we sure that the holes are actually too large to use straight pull spokes without washers?
ergott
by ergott
Oh and how do you plan on threading spokes through those holes without bending them?
But what do I know.
Stefano
by Stefano
Listen to ergott or you're gonna end up costing yourself a lot of money... he's a pro and definitely knows better. Also, I guess I was unfamiliar with the hub geometry, but there is no way youll be able to thread those spokes safely/without bending them
