Lightweight care
mattyNor
by mattyNor
So I'm the new proud and slightly paranoid owner or a set of gen3 lightweight standards. As I bought them used and thus have no ability to warranty anything I'm really babying them.
I'm in the process of regluing them and got as far as scraping the old glue off and hit my problem. Seams as the og owner did a layer of glue, then tape, then glue, then finally the tire! I've gotten most of it off but I'm stuck with a very sticky layer at the bottom now. What I'd normally do is wet the surface with rubbing alcohol and let sit for a few hours. Is this safe to do with these wheels and are there any better options?
Also what would be involved to remove the decals since they seam to be under the clear coat? I've designed some replacements that match my frames font and colours that I'd love to use.
Cheers
Gazelleer
by Gazelleer
Sticky = good
I'd remove the bigger lumps of glue that are still there and then add a new layer of glue on top of the remainder to fit the new tubulars.
Mackers
by Mackers
After which you find out the hard way the other guy used a different kind of glue that doesn't play nice with the glue you used.
Just use plenty of rags and white spirits and get all the old glue off.
sungod
by sungod
alcohol isn't that good for glue removal, it flashes off fast
petrol, white gas, white spirit etc. are all better
schwalbe glue remover is good, but availability varies
this stuff is also good, maybe best...
http://www.desolvit.co.uk/products/stai ... -spray/18/
...as with the schwalbe, it's a gel
equivalents should be available, look at the datasheet to see contents
Geoff
by Geoff
First, I would agree with the other posters that unless you can confirm with certainty the type of glue on the rim now, the best choice is to strip it bare. I would also agree with the comment that alcohol is not going to help you to do that. I would recommend a product like Goof-Off or any household solvent (paint thinner). Just use lots of fresh rags and it will come off. Once you have the rim free of old glue, then you can use your alcohol to clean the rim.
With respect to the durability of the LW wheelset, I know that the natural reaction is to 'baby' the wheels, but they are honestly very durable. Once you have rammed them hard into a few potholes, you'll get over your phobia!
NiFTY
by NiFTY
Enjoy the wheels, I agree with Geoff, ride them like any other wheelset (maybe not in the wet so much). I have meilenstein clinchers *gasp clinchers* and they are very strong. I have ridden about 7,500 k's on them with a fair bit of climbing (I did 190 vertical K in under 11,000 horizontal last year). I have done a fair few steep technical descents without issue (but will say I was conscious about the clincher delamination possibility so was mindful not to drag the brakes the whole descent.) I have hit a fair few big potholes that have made the frame shudder but the wheels have been fine. I would also say get the black prince pads - they are cheaper and easier to find then the lightweight branded pads and have better performance.
mattyNor
by mattyNor
I've been using Reynolds pads since that's what I had lying around.
