Campagnolo 100gr defect!
dj97223
by dj97223
Indeed.
OP -- look at it this way: the weight is in the hub, where it matters least.
wowja
by wowja
bikerjulio wrote:
wowja wrote:Ok so I called Campagnolo North America and they explained the 100gr difference is due to a steel Shimano/Sram freehub body vs the alloy Campagnolo. So I guess it makes sense freewheels designed for a market competitor is made with cheaper (heavier) materials.
Will I be able to buy a titanium or alloy shimano/sram freewheel for the Campy hubs? I tried searching but seems unclear if its interchangeable.
I asked you if it was a shimano freehub.
And the answer was "no".
Sorry, I think I was delirious from work when I read it.
The Shimano cassette body is steel as they use far shallower splines than Campagnolo, and the load bearing area is far smaller in consequence - Shimano use steel in their own product - it's got nothing to do with Campagnolo making for compatibility with a competitor at a cheaper prices / heavier material, it's just basic engineering.
You need to bear in mind this is the same part as they use in the Fulcrum wheels, which are targetted at the OE market with it's preponderance of Shimano (and in come markets, SRAM) components.
AFAWK there are no Ti cassette bodies available to fit Campagnolo hubs, with Shimano *or* Campag splines - anyone know of anything out there?
This was helpful and makes a lot of sense. Now time for me to put last parts together and go ride!
wowja
by wowja
BTW, tires were such a b*tch to get on, which I knew from reading other's experiences. I went out and got some velo plugs and its much easier now. =)
Tenlegs
by Tenlegs
Today I received a set of Neutron Ultra's (campy freehub) front 680g rear 908g to replace a 2013 set of Zondas front 700g rear 880g (not 2way and same scales)
So a net gain of 8g! + the weight of rim strips which the Zondas don't use, wish I'd just stuck with the Zondas,
campy's not being honest with weights anymore, while the Zonda's are fairly close to claimed the Neutrons are way over.
dj97223
by dj97223
"Campy's not being honest with weights"? My Bora 35's weighed exactly what Campag said they would.
Tenlegs
by Tenlegs
I thought this thread was about Neutron Ultras being overweight?
I'll post some pics on a scale soon
viewtopic.php?f=3&t=125551
liam7020
by liam7020
No offence to Campag USA but that's complete and utter bollocks! I have the Campag version and they weigh 1573 take away the weight of the rim tapes at 41g and that leaves you with a wheel weight of 1532 which is considerably above the stated weight. I've heard that Fulcrum wheel weights can also be taken with a huge pinch of salt. In fairness to Shimano their stated component weights are also right on the money.
Belgian Flag S-Works Tarmac viewtopic.php?f=10&t=144553
