How high do you pump?
What average tire pressure do pump to - most often?
Poll ended at Mon May 26, 2014 1:25 am
<80PSI
7%
90PSI
16
18%
100PSI
32
37%
110PSI
22
25%
120PSI
10
11%
130PSI
1%
140PSI
No votes
>150PSI
No votes
Total votes: 87
ergott
by ergott
I'm mostly using Hutchinson Secteurs as 60psi on the road. Man that's a nice ride and I'm no slower.
On the nice weather bike I have Veloflex Extremes that I pump to about 95-100psi. I don't break 100psi for any tire. I'm around 77kg or less.
HillRPete
by HillRPete
Challenge Almanzo 30mm: 3bar front / 3.5 rear
Vittoria Pavé 27mm: 4 / 4.5
Conti 25mm tubs: 5 / 5.5
22-23mm tubs and clinchers: 6 / 6.5
I weigh a bit over 70kg, and roads smooth, gravel often on the rougher side.
dgasmd
by dgasmd
88 kg.
Tubular vittoria
115 in front and 115-120 rear.
Why? Because that is what I've always done LOL!!!!!!!
martinko
by martinko
72kg and GP4000s clinchers that say "pump us to 7-8.5 bar". So I pump ~8bar both (116psi). And so, in the last 3 years only one flat (but that was strange one). I remember the days when I pumped 5bar (72psi) and flatted 5 times per year. So I am not going back ;)
fiti
by fiti
100 front, 110 rear. Veloflex Corsa 23 mm clinchers. One pinch flat in last 3 years. I'm 69 kg.
fiti
Tom-s
by Tom-s
70kg on 25mm Michelin pro4 clinchers with vredestein latex innertubes @ 70 psi front / 75 psi rear (thats 5.0 / 5.2 bar) and about 5 - 10 psi less in the rain.
ayrej2
by ayrej2
25mm Conti 4 seasons, 79kg. 80 front, 85 rear, but then I only pump up once a week, so they're down to 65-70 for most of that time. Haven't had a pinch flat for years.
I really don't understand why people buy 25mm's then pump them up rock hard negating all the benefit!
efeballi
by efeballi
To avoid pinch flats and damage to the rim.
For me, I want as much air as possible between my rims and the sharp edge of a pothole. Comfort and performance take second place.
I used to pump 80/85 psi on 25 mm Grand Prix'es and they were getting pinched, damaging the rim twice.
Im 67 kg btw.
SHUT UP LEGS
2015 Giant Propel Advanced
2013 KTM Strada mod. GOT IT BACK!
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
dlcrep
by dlcrep
I run 95/103 psi on Conti GP4000S over 23mm wide wheels, weighing in at 68kg
bm0p700f
by bm0p700f
If I am using latex tubes on a very long ride I may start at 100 psi but by the end it will be less.
Nicos
by Nicos
100/105 psi (7/7.5 bars) on GP4000S
Causidicus
by Causidicus
Rush
by Rush
100 psi on 23 or 25c tires on 19 or 23 mm rims.
I've tried running lower pressures on 23 mm rims but I get bad punctures. I'm 6'3" and about 88 kgs...I've come to the conclusion that I can't run lower pressures.
Bogan
by Bogan
Ultremo ZX 105 to 110. Haven't had a flat for a long time, touch wood. I am about 95 kegs.
MAMIL? Never. O.F.I.L. yeh! (Old F**ker in Lycra)
pdlpsher1
by pdlpsher1
I weigh 62kg however I run a very high pressure. Anything less than 120psi I have a flat tire! I know this is crazy but I need every bit of speed to keep up with the group rides that I do. Even if there's no speed benefit it does give me a psychological boost...
