How high do you pump?
What average tire pressure do pump to - most often?
Poll ended at Mon May 26, 2014 1:25 am
<80PSI
7%
90PSI
16
18%
100PSI
32
37%
110PSI
22
25%
120PSI
10
11%
130PSI
1%
140PSI
No votes
>150PSI
No votes
Total votes: 87
Zoro
by Zoro
This poll is about what you actually pump you tires too when doing your "fast" riding on pavement on a road bike. Use the average between front and read pressure.
I understand answers might be different with clinchers vs. tubulars, front / rear, width, material, TPI, casing, types of roads, weight of rider and type of riding.
Feel free to elaborate in your post as to why.
mentok
by mentok
90kg, 23 and 24mm wide rims with 23c tyres - 80 to 90psi standard. i couldn't tell you the last time i pinch flatted and i think the lower pressures help avoid slashing on the small rocks we seem to get a lot of in the shoulders around these parts - they seem to bounce away rather than dig into the sidewalls...
Flyfishing3
by Flyfishing3
Checked 110 but use 115 on 25mm GP 4000s
btompkins0112
by btompkins0112
+1 on 80-90 psi
Sent from my SM-N900V using Tapatalk
kaaos
by kaaos
tubular Continental Competition 22mm
95psi front
100psi back
I weigh 73kg
Johnny Rad
by Johnny Rad
Rear: ~105psi
Front: ~100psi
23c clinchers and 73kg
When I was heavier at 79-82kg, tires were pumped ~5psi higher.
TuplaO
by TuplaO
I voted 100 PSI
Rear: 100-110
Front: 95-100
Applies for Veloflex carbons. With Arenbergs, I may go slightly lower. I weigh a tad under 90 kg.
sugarkane
by sugarkane
85kgs ish
Carbons and extremes 90 front and 97-100 in the rear.
In the wet 5psi less maybe another 5 if I thought it was really slippery
Got some arenburgs in the works looking forward to knocking the start pressures down 10psi :mrgreen:
Causidicus
by Causidicus
NealH
by NealH
80#, front and rear on Conti 4000 in 25. Great ride and performance.
shoopdawoop
by shoopdawoop
I weigh 60kg and I typically go 90/95psi unless I know I'll be encountering some rough roads then I usually go 80/85.
Geoff
by Geoff
Well, I would always recommend different pressures for the front and rear. With my preferred hand-made 22's, I run 90-100 front and 100-110 rear, depend upon the road conditions. With a 'deep' set of race wheels, I will run a 25 on the rear, so will run a slightly lower pressure. If you are a bigger rider, I would not recommend running a new Hed/Zipp 'deep' rim bed on the rear without a 25 or less than 90psi for racing in good weather. The risk of pinch-flats is too high.
I am also trying-out tubeless tires as an experiment! I have been playing-around with the pressures and have been down as low as 70psi with no problems.
kode54
by kode54
Causidicus wrote:
Johnny Rad wrote:Rear: ~105psi
Front: ~100psi
23c clinchers and 73kg.
Try 100 rear, 90 front. Even that may be a bit high.
that's my typical pressure...and when it rains or the roads are wet...10-15psi less all around.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
eric
by eric
95 psi front, 100 rear.
I'm 145 lbs (66kg). 23mm clinchers.
I have used 85f/90r for an extremely bumpy race with no pinch flats.
efeballi
by efeballi
90 front, 100 rear. Using 25mm Conti GP4000S clinchers on 17 mm wide Ultegras.
Pretty rough roads here and no pinch flats yet.
SHUT UP LEGS
2015 Giant Propel Advanced
2013 KTM Strada mod. GOT IT BACK!
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
