It is currently Wed Jan 17, 2018 9:44 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Thu May 01, 2014 4:35 pm
Hi guys,
Hoping for some advice as my head is frazzled trying to decide what wheels to get!
Basically I want to purchase a set of wheels that will satisfy my road bike needs as well as being able to use them for the odd club tt I do. I also have a powertap that I would like to build into the rear wheel build. Unfortunately it is a 32 hole tap.
I'm considering buying a set of 50mm deep carbon rims from China (aware of the dangers re heat build, happy with supplier etc) with 24h front and 32h rear so that the tap can be used. I'd probably use a wheel cover on the rear for the tts. So what do you guys think? Will the fact that the rear is 32h make a massive difference? If so I'm thinking I might be better trying to sell the tap and buying one to fit a 24h wheel (or a dura ace crank perhaps). Also do you think the 50mm deep is a good compromise to allow me to use the wheels for tting and road use (especially given that I will be using a cover)?
Appreciate any thoughts and advice. Cheers!
PostPosted: Thu May 01, 2014 4:41 pm
32 spokes will not cause a major drag penalty.
Also, I ride 50mm wheels every day and they are just fine in all conditions.
The cover is a good choice as well
Sent from my Nexus 7 using Tapatalk
PostPosted: Thu May 01, 2014 4:47 pm
Thanks Vdrey. That's good to know!!
PostPosted: Thu May 01, 2014 5:23 pm
If you are concerned about 32 spokes you could also built you rear wheel with a 8:16 pattern.
I'm not a specialist in this matter, so maybe other can give their opinion on this.
PostPosted: Fri May 02, 2014 12:08 am
Interesting option that 16:8
Is there a reference to how the lacing should be and how to calculate spoke length ?
Hucken The Fard Up !
Colnagos : C50 ST01 - Master 30th AD10 - C40 Mapei WC
PostPosted: Fri May 02, 2014 8:43 am
Thanks TimmS. I did look at that option, but had concerns about fitting a square peg in a round hole and ending up with a less than optimal solution.
PostPosted: Fri May 02, 2014 10:06 am
What model Powertap is it and how heavy are you? The flanges on a PT are odd sizes and usually the more spokes the better in my opinion.
Strada Hand Built Wheels
http://www.stradawheels.co.uk
PostPosted: Fri May 02, 2014 10:42 am
Here you can find a spoke calculator able to handle 16:8 lacing.
The lacing is quite simple, but this description unfortunatly is in german only. Maybe the picture tells enough.
PostPosted: Fri May 02, 2014 11:22 am
I think that a standard 32 spoke with 2 or 3 cross lacing would be the best decision because it is really simple and also very strong.
Just make sure to use bladed spokes of some kind.
PostPosted: Fri May 02, 2014 2:40 pm
Cycleops (the older heavier one)
PostPosted: Fri May 02, 2014 2:41 pm
Thanks Vdrey
There are no new unread posts for this topic. Road disc wheels - making the jump, what should I get?
in Everything wheels
gerryc89
Tue Mar 28, 2017 12:43 am
jeffy View the latest post
There are no new unread posts for this topic. SuperX wheels & tyres for road/light gravel
CarlosFerreiro
16
1039
Mon Oct 02, 2017 1:15 am
menkar View the latest post
There are no new unread posts for this topic. Any comment or reviews on these wheels, Vision TC24 Carbon Road Wheelset
merlinxlm
Fri May 19, 2017 6:01 pm
m66 View the latest post
There are no new unread posts for this topic. Alloy road bar with a drop curve like the ENVE SES Aero Road Bar?
VTR1000SP2
11
1853
Wed Oct 04, 2017 4:08 pm
cwdzoot View the latest post
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
1961
Wed Jan 03, 2018 3:28 am
morganb View the latest post
Users browsing this forum: AZR3 and 10 guests
cron
