It is currently Thu Jan 18, 2018 7:05 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
 Post subject: Re: Chris King R45 Issue
PostPosted: Mon Apr 14, 2014 11:10 am
What material is the dropout made from? (I didn't see it referenced in the original post.) If you're riding a ti bike with 6-4 drops, they are very hard and quick releases - particularly less effectve light ones with light materials less effective cam - tend not to grip well.
Regardless, the best solution is to use the best no BS QR, which is Dura Ace. The older Record comes next, and everything else trails.
 Post subject:
PostPosted: Tue Apr 15, 2014 7:18 am
PostPosted: Thu Apr 17, 2014 11:39 pm
I will throw my 2 cents in. It is possible that the R45 hub 9mm fork tip interface (that bit that sits in the drop outs) is a bit longer than the other hubs you mentioned. If so the skewer may be contacting the hub before the face of the drop outs. Some skewers have an internal dome shape anticipating this very issue. I only bring this up because you mentioned movement on the front wheel and even bad skewers will not allow you to move the wheel in the drops simply with your hand. As for noise it is either the movement between the hub and drop outs or the external cam on the skewer is dry and needs lube. Let me know if this helps.
"If the frame is the heart of the bicycle, the wheels are its soul". Richard Craig
www.prowheelbuilder.com
PostPosted: Fri Apr 18, 2014 5:01 am
Threw in some Dura Ace QR and problem solved. Moved the Zipp QR's over to a wheelset with Dura Ace hubs and they seem to hold in that combination.
wheelsONfire wrote:
When we ride disc brakes the whole deal of braking is just like a leaving a fart. It happens and then it's over. Nothing planned and nothing to get nervous for.
PostPosted: Tue Jun 09, 2015 8:47 pm
I’m rather sceptical of the idea of increasing the QR clamping force to eliminate creaking in Chris King hubs. I’d expect to see an unacceptable rise in bearing friction from excessive lateral pre-load, when instead I want to barely eliminate lateral play. Instead, on my 2014 Wilier Cento Uno, I found that the front R45 hub of my Enve creaked because of visibly [?forged] uneven faces on the tips – particularly on the internal faces which meet the smooth alloy clamping faces of the hub. It was an easy job to patiently re-surface them with a fine file, ensuring the elimination of a light gap with a blank axle and a pair of smooth Campag locknuts on each side to maintain the alignment. I’d suggest that Chris King hubs should only be installed where truly flat, true surfaces are available for clamping – there’s no hint of a creak in Easton EC90SL moulded carbon tips or in any rear vertical dropouts including Merlin’s titanium, and the lower clamping force of titanium external cam QRs is quite sufficient. If this idea has arisen previously, then I’m sorry to say that I missed it in the predominance of solutions based on QR robustness.
PostPosted: Wed Jun 10, 2015 8:08 pm
This is definitely good advice, and is applicable to any hub whose bearing preload is influenced by QR clamping force (DT/Chris King/et al). It would be worthwhile to check your dropout alignment, front and back, with the appropriate tools. You can unnecessarily wear out your bearings by cranking down your QR to compensate for bad dropout alignment.
Hermes Sport, San Diego CA
Handbuilt Competition Wheel Systems
http://www.hermes-sport.com
There are no new unread posts for this topic. Which Skewers for Chris King R45 Hubs?
dim
Sun Jan 07, 2018 8:44 pm
jrccomponents View the latest post
There are no new unread posts for this topic. Chris King R45 Campagnolo hub problem?
wilwil
7
890
Mon May 29, 2017 1:14 pm
wilwil View the latest post
There are no new unread posts for this topic. Will the new Chris King T47 Bottom Brackets fit on my THM SE cranks?
kode54
Fri Mar 31, 2017 3:37 pm
Denavelo View the latest post
There are no new unread posts for this topic. 2017 De Rosa King XS
[ Go to page: 1 2 3 4 ]
nismosr
52
9644
Wed Nov 29, 2017 3:32 pm
nismosr View the latest post
There are no new unread posts for this topic. Attachment(s) Madone is the aero king - why?
[ Go to page: 14 5 6 7 8 ]
alcatraz
107
8399
Wed Nov 22, 2017 3:33 pm
mag View the latest post
Users browsing this forum: Bing [Bot], craddlepig and 7 guests
