It is currently Fri Jun 23, 2017 6:45 am
Post new topic  Reply to topic  [ 15 posts ]
 Post subject: Archetype question
PostPosted: Sun Mar 30, 2014 3:31 pm
Looking at rims and came across this statement from DCR-Wheels
H Plus Son have the sa at a 20:24 lacing on this rhyme will hold a rider of up to 200lbs or 91kg.
Now that I weigh just over 91kg. Should I choose 24/28h instead of 20/24?
They will probably be thrown on a set of Hope Mono RS as CK R45 11speed not seem to be in stock with AVT right away.
What do the pundits out there say?
Custom Rychtarski steel bike
Ridley X-ride 10
Custom Wittson Ti
 Post subject: Re: Archetype question
PostPosted: Sun Mar 30, 2014 6:24 pm
Yes, go higher spoke count. No need to push the envelope to save 20 grams when you are heavy rider, this might cost/hurt a lot
PostPosted: Sun Mar 30, 2014 7:42 pm
I'd go 24/28. Flexible wheels aren't fun.
PostPosted: Sun Mar 30, 2014 10:18 pm
The archetype is stiff but not stiff enough for 20F/24R for your weight. A 24F/28R built up with CX-rays will be as stiff as the lower spoke count built with sapim race and be the same weight. Higher spoke count make sense here.
If you want 20F/24R pick a stiffer rim, Pacenti SL23 or Kinlin XC-279 even then if you want long spoke life go with 24F/28R or 20F/28R You get the idea.
www.thecycleclinic.co.uk
PostPosted: Sun Mar 30, 2014 10:38 pm
Where would later version Stans Alpha 340s (20/24) fit in this scale?
PostPosted: Sun Mar 30, 2014 11:00 pm
Even worse put a 91kg rider on those and you will have a wheel that will break spokes in short order far to flexible and that what will do the spoke in.
PostPosted: Mon Mar 31, 2014 5:16 am
:beerchug: 24/28 it is.
Thanks a bunch!
Ridley X-ride 10
Custom Wittson Ti
PostPosted: Tue Apr 01, 2014 2:40 am
Those would be the least stiff by a good margin. I'd put the Archtype and SL23 at a tie, with the XC279 the stiffest.
formerly rruff...
PostPosted: Tue Apr 01, 2014 11:52 am
Archetype and SL23 at a tie? Even with more weight and less surface area?
PostPosted: Thu Apr 03, 2014 5:00 pm
I think that the SL23 is a better rim than the Archetype. It's wider, deeper, and still lighter than the H Plus Son and it has a nicer finish.
http://www.zencyclery.com
PostPosted: Thu Apr 03, 2014 8:12 pm
Stiffness. The Archetype is 20-25g heavier with slightly smaller dimensions.
formerly rruff...
PostPosted: Sun Apr 06, 2014 7:14 pm
My own experience of the archetype and SL23 is the SL23 at 28 holde drilling with the same hubs and spokes takes more sideload to slacken NDS spokes than the archetpe does. I agree the Kinlin XC-279 is even stiffer.
PostPosted: Wed Apr 09, 2014 8:12 pm
I am a heavier rider about 100kg and I am considering to have a pair of wheels build with the Archetype rim using the 28/32 configuration. What kind of hubs and spokes should I consider using or what do you guys recommend in terms of wheels for someone my size. recreational rides up to 120 kms usually no crits or races here ..
Thanks
PostPosted: Thu Apr 10, 2014 12:02 am
@StreetR- If I were you I'd lace up your Archetypes to the T11s from White Industries. They aren't super popular on here because they come in at 345 grams for the set, but I've found them to be outstandingly durable even for larger riders such as ourselves. Those laced with Sapim Lasers 3x all around would be more than stout enough for your weight. I'd also recommend going with brass nipples on the DS, or even all around if you don't mind the extra 15 grams.
PostPosted: Thu Apr 10, 2014 6:31 am
Thank you Zen .. What is the total weight of the wheels with the White hubs and the brass nipples you mentioned ?
There are no new unread posts for this topic. H+Son Archetype and Dura Aces: can you remove the brand decal?
in Everything wheels
RChevalier
Fri Sep 02, 2016 5:31 am
Kurets View the latest post
There are no new unread posts for this topic. MTB fit question?
in Training
jmaccyd
10
861
Fri Aug 19, 2016 3:33 pm
MikeMoore View the latest post
There are no new unread posts for this topic. bc1.37 bb question
urbanspaceman
9
366
Sat Jun 03, 2017 7:18 pm
urbanspaceman View the latest post
There are no new unread posts for this topic. Shiv TT question?
CrankAddictsRich
Mon Jun 12, 2017 6:18 pm
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Colnago C59 question...
lone wheeler
7
802
Tue Oct 25, 2016 1:53 pm
fromtrektocolnago View the latest post
Users browsing this forum: No registered users and 3 guests
