It is currently Sun Oct 22, 2017 3:11 pm
PostPosted: Mon Mar 24, 2014 2:26 am
Hi guys, I wrecked the front rim of my DA7900 C24 wheelset. Instead of buying another DA rim from Shimano, I would like to re-lace the DA hubs to aftermarket wide rims. Pacenti, H PLus Son, etc.
My question is with the C24 hubs being 16 front and 20 rear, will I be able to build up a set of wheels stiff and durable enough as my everyday training wheels? I weigh 165lbs. Don't put down a ton of power but do ride on crappy roads and even gravel sometimes.
PostPosted: Mon Mar 24, 2014 11:27 pm
Those hubs need shimano spoke I think so it is a none starter. Also try finding a alloy 16H clincher. They do exist but no common either.
www.thecycleclinic.co.uk
PostPosted: Tue Mar 25, 2014 5:58 am
@grnrcr - Good luck finding a rim. There are a couple of fairly common options with 16h drilling like the KinLin XR300 and Velocity DeepV but they're quite narrow. AFAIK most of the new 'wide' rims only go down to 18h.
@bm0p700f - 7850/7900 series wheels use a regular straight pull spoke. 7800/7801 use the double ended spoke.
PostPosted: Tue Mar 25, 2014 10:25 pm
Well thats good to know.
PostPosted: Wed Mar 26, 2014 12:05 am
I think it would be damn near impossible to find a wide 16 hole rim. You could take a 32 hole and just use every other hole but the drilling offset wouldn't be correct at that point.
http://www.zencyclery.com
PostPosted: Wed Mar 26, 2014 1:31 am
Can you weigh those hubs before you build? I have an estimate but never seen an exact weight. Also, can you weigh your rear rim? Thanks.
PostPosted: Sat Mar 29, 2014 7:24 pm
So if I use the XR300 rims, what are the chances of building up a set of wheels durable enough at 16/20?
PostPosted: Sun Mar 30, 2014 7:54 am
I would email and ask Kirk Pacenti if he can make a SL32 with 16h. Sometimes manufacturers have a few undrilled rims lying around and can drill it on demand.
PostPosted: Sat Apr 12, 2014 7:34 am
I just wrecked a WH7850-SL rear rim and the hubs are prefect (free hub is less than a year old thanks to a warranty issue). Does anyone know of a rim that could be used to build up a new rear ?
Cheers
Dave.
PostPosted: Sat Apr 12, 2014 3:50 pm
When my C24 rims go, I'm going to get some of the 38mm carbon clinchers from light bicycle. 380 grams of T700 carbon will be plenty stiff.
There are no new unread posts for this topic. SOLD Enve 4.5 SES Laced to Tune Mig/Mag Hubs (Tubulars) - $900 shipped
RyanH
Sun Sep 03, 2017 2:34 pm
RyanH View the latest post
There are no new unread posts for this topic. Parlee Z5 SLi & wide rims
audiojan
11
964
Tue Jun 06, 2017 9:21 pm
rst72 View the latest post
There are no new unread posts for this topic. Old SuperSix, 23mm wide rims?
toshi
10
1644
Mon Jun 05, 2017 9:22 pm
tarmackev View the latest post
There are no new unread posts for this topic. TRP r979 eq ?? Will they clear 27mm wide rims?
Allen254
Sun Mar 05, 2017 7:39 am
Nefarious86 View the latest post
There are no new unread posts for this topic. Wide tubular tires on narrow rims
in Everything wheels
RyanH
22
1337
Sat Sep 23, 2017 10:56 am
sungod View the latest post
Users browsing this forum: AJS914, Google [Bot] and 5 guests
