Show us your punchtures and say a bit about it
Zoro
by Zoro
I didn't see this thread, so here goes. Post a picture of your punctures and any comments. Comment on how you repaired it / or not and any other info.
Zoro
by Zoro
One of the safety pins used for race numbers went all the way through.
There was a crash about 2 hours before. Race went another 5K on this an it was not leaking.
I tried Vittoria PitStop and it worked at about 90psi. then I pumped up to 130psi and it started bubbling the casing. I believe the pin went through both side of the tube. I will send out for tube replacement.
kevhogaz
by kevhogaz
Brand new Veloflex Arenbergs. Less than 100 miles on the tires. These replaced some Schwalbe tubulars, that I ran over a razor blade on.
10 miles in to a 60 mile climbing ride, I get this. Not sure how it went through sideways, but it did. This was the end of my use of tubulars on crappy Phoenix streets!!
Zoro
by Zoro
In a real bad kind of way, that makes me feel better.
Somehow - feels like most the flats would have happened on anything. I guess an armor ribbon under the tread might have prevented some of these, but is it worth it?
Illuminate
by Illuminate
Decided to try a Schwalbe Durano Plus after a few flats with my Veloflex Corsas. Also run a Panaracer Kevlar ribbon inside. No flats on the Schwalbe in just under 2000km. They're heavy and slow rolling (squishy too) - quite squared off but I'm a heavy rider.
Will provide feedback when I'm back onto the Veloflex (but this time running the Kevlar puncture belting/liner).
