Reusing DA 7850 straight pull hub
athos
by athos
I have a DA 7850 straight pull rear hub from a broken c50 wheel. The hub is fine and I would like to use it again. Some questions:
1. Is the hub is compatible with standard (DT or Sapim for example) straight pull spokes? I think it is but I'm not 100% sure.
2. How do I calculate the correct spoke length? Any pointers on how to do this? I read the post from ergott to 'reverse engineer' this by checking the old spokes and old rim ERD. (viewtopic.php?f=3&t=89693#p774717) Is this the best way?
3. What (cheap?) rim would be strong enough to accommodate a 70 kg rider on a 20 spoke rear wheel?
An option I found is this: http://www.cnc-bike.de/product_info.php ... ts_id=9694
The seller told me that is it suitable for a 70kg rider and that it isn't a H Son Plus SL42 (I thought it might be)
Thanks!
Zen Cyclery
by Zen Cyclery
These aren't standard spokes that you could simply replace with a DT or Sapim. You will have to rebuild with Shimano rims/spokes seeing as the nipples thread into that rim, instead of the traditional style where the nipples thread into the spoke.
jooo
by jooo
@Zen Cyclery - Nope, you're probably thinking 7800/1 or the 7850 C24's (except for the full carbon tubular).
@athos - 7850 C50 use normal spokes so there are no issue reusing the hub with another rim. The 'blade' dimensions are the same as CX-Ray (pretty sure I remember reading somewhere they were even made by Sapim). ergott's method for finding the spoke length sounds good provided you've still got the original rim :thumbup: The original spoke length is 278mm according to Shimano tech docs.
Are you trying to find a replacement rim to match the height/appearance of the Shimano front, or will anything do provided it's strong enough for you?
athos
by athos
I think jooo is right, this is the more traditional style wheel. Difference I think is that the thread and nipples are larger as compared to standards.
jooo wrote:Are you trying to find a replacement rim to match the height/appearance of the Shimano front, or will anything do provided it's strong enough for you?
It doesn't really matter what it looks like, just a rim that is strong enough and isn't very expensive. I may also redo the front wheel. (16 spoke)
F45
by F45
I'd look into Kinlin XR380 or one of the 38mm carbon clinchers from light bicycle.
