It is currently Fri Jan 19, 2018 4:58 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Tue Feb 25, 2014 2:28 am
Ok. So the big question.
2014 zipp 404 (24 spoke rear ~much stiffer than 2013's), in a ridley noah (2012-14) frame (fast or pro) on 23mm tyres.
Has anyone done this combo?
If yes does the tyre rub in a sprint?
I have heard the old 20 spoke zipps do rub. I have also heard enve 6.7's don't.
Many thanks
Peter
PostPosted: Sun Mar 02, 2014 8:41 am
So I'm guessing this hasn't been tested. Well I guess I'm the guinea pig then.
PostPosted: Mon Mar 03, 2014 6:10 am
I'll be interested to hear the results. I'm debating between 404s and 6.7s for my AR1.
PostPosted: Fri Jul 25, 2014 5:57 am
so far so good. but proper bunch sprint will test it for sure.
PostPosted: Fri Jul 25, 2014 11:42 am
Which year frame are you on? 'Fast' or regular? 404's are clinchers or tubs? 2014 zipps w/ the newer, stiffer hubs?
Rim widths are here
http://www.slowtwitch.com/Tech/Rim_Widt ... _4370.html
PostPosted: Fri Jul 25, 2014 3:17 pm
Did you email/ask Ridley? I thought Specialized was the only one with the Tarmac/Venge on the old molds that would rub on "wide" rims. Haven't heard of other issues with other brands. But then again..you never know.
PostPosted: Mon Jul 28, 2014 4:53 pm
You can check out the 'passport' for the Noah on their website. Has info about wheel compatibility.
http://www.ridley-bikes.com/gb/en/bikes ... noah-1303f
PostPosted: Fri May 22, 2015 2:19 am
Btw. The 2014 404s FC clincher don't rub. And you can even run 24mm tyre on the rear. I'm 75kg and sprint regularly. Not an issue. To be honest the front 'looks' tighter
PostPosted: Thu May 28, 2015 7:09 pm
Contrary to some of the responses above if you a sprinter/out of saddle aggressive climber then the wheel will not work. I ran into the same problem as you when I went from a set of ENVE 65 with 28 holes/DT Aerolite nds 2X+DT AeroComp ds 2X/Powertap Pro+ hub/Continental GP4000S 700x23C to my current Campagnolo Bullet 80 wheels. The former wheels (plus a handful of others) resulted in tire rub along the chain stays AND seat stays.
I even contacted Ridley and inquired if Andre Greipel was using a custom frame because I was experiencing tire rub from wheel flex. I am a former track cyclist who generates anywhere from 1600-1787 watts in a sprint and this would result in complete paint removal from the chain stay/seat stay inner surfaces and tire wear along the sidewalls of my tires. Ridley responded and said that it shouldn't be happening. I believe the tight tolerances are to blame since the Ridley Passport info indicated there is only 30mm of clearance…a standard 23C tire would yield 3.5mm on either side and depending on paint thickness it might be closer to 3mm on either side.
In my case I purchased Campagnolo's Bullet 80 USB wheels and Continental GP4000S 700x20C tires to give me some additional clearance. After trying a myriad of wheels I believe the Campy aero clincher wheels are the stiffest wheels on the market. I have tried Mavic Ksyrium Elite/SSCs, Enves mentioned above, Kinlin XR300/White industry 28 hole/DT Comp 2X wheels, Bontrager Race TLR, and ENVE 6.7.
The take home message is the wider the rims the less tire clearance you will have with the chain stay/seat stay area. I think Conti GP4000S 700x23C tires turned out to be around 24-25mm wide on the ENVE SES 6.7 which left 2 mm of clearance on either side of the tires. Zipp Firecrest wheels will most likely leave similar clearances and even the newer 24 spoke wheels will flex too much.
PostPosted: Fri May 29, 2015 11:21 am
Well that's interesting.
I will add:
Noah pro is stiffer than noah fast - I was referring to the pro in case that needed to be cleared up.
I don't know what wattage I pull but at the end of my bunch ride I hit 64-69 km/hr depending on day / wind and I'm 75kgs. With the 24 spoke 2014 fc and gp4000s I'm yet to experience rubbing but I haven't put tape there or anything to test for sure / that can be my next step.
PostPosted: Tue Jun 02, 2015 3:29 pm
I will add:
Just an FYI, I too own a Noah Pro and used to own the standard Noah. Both bikes experienced the same issues. Additionally, according to some email exchanges with Ridley back when I was looking for a wheel set that would work with the frame the guys at Ridley said that the Noah, Noah Pro and Noah Fast were all similar in frame stiffness. The new Noah SL is supposedly more compliant but I haven't seen any data supporting this.
Trust me when I say I was really frustrated when the wheel rub occurred because it literally rubbed the paint down to the carbon. Additionally, when I started my search for a replacement frame (thinking maybe the frame was too flexy) I realized that it was one of the stiffest frames on the market. I believe Ridley made the wheel tolerances too tight for practical use without it incurring some collateral damage to the paint. Thinking I was some kind of beast on the bike I have noticed this same issue on two other Ridleys and both riders are noticeably smaller than I am (one was a female sprinter but maybe 100 lbs soaking wet!!!).
Now whenever I visit the bike shops I find myself looking at the chain stay/seat stay tolerances in anticipation of my next bike purchase. Because my other bike (Colnago CLX 3.0) is not as stiff but I have no tire rub on that bike.
PostPosted: Wed Jun 17, 2015 1:04 pm
Truly staggering. You need the enve 65 classics 22mm wide. Anyways I'm still doing ok. No real evidence of rub yet but I have matt black paint. And only sprinting once a week right now. I'll keep monitoring. I guess when you jump (getagapholdagap) that's when it happens
PostPosted: Tue Aug 04, 2015 12:40 pm
hppy4u2 -
After doing enough kms i can concede that i am getting some tyre rub on the drive side at the seat stay area.
I have measured clearances as follows:
- 3mm (tops) between tyre and seat stay (drive side)
- 4mm between tyre and seat stay (non-drive side)
I gather having a difference in clearance on each side as above (difference is noticeable by eye) is normal?
Also note that where the tyre meets the bottom bracket the wheel/tyre looks centered but upon measuring:
- 5mm of space on the drive side between sidewall tyre and frame
- 6mm of space on the non-drive side between sidewall tyre and frame
Can i have the rim moved 1mm to give me more clearance at the seat stay area? Or is this not possible?
From what i can gather, the wheels where purchased as is and installed 'as delivered' like most wheels are.
PostPosted: Sun Nov 19, 2017 4:49 pm
just bring up an older topic, will the new wider Campagnolo Bora's run on a 2015 Ridley Noah Fast (Integrated brakes) without rubbing the chain stays? ideally, it'd like to run Vittoria Corsa 25's.
There are no new unread posts for this topic. How to make my Ridley Noah SL lighter??
fonzo89
12
1769
Thu Jul 06, 2017 10:55 am
hannawald View the latest post
There are no new unread posts for this topic. Attachment(s) Ridley Helium 2016 xs/3t Rigida LTD/Zipp 202
reedplayer
Sat Dec 16, 2017 11:11 pm
reedplayer View the latest post
There are no new unread posts for this topic. Wanted: UK -100mm Enve, Zipp Sprint or Zipp Speed Stem
in Wanted
iamalex
Sat Jan 06, 2018 1:03 pm
iamalex View the latest post
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. Domane 2.3 2014
kordis1
Mon Oct 30, 2017 10:38 pm
FIJIGabe View the latest post
Users browsing this forum: No registered users and 2 guests
