Most Durable Clincher Brake Track
Mr.Gib
by Mr.Gib
Does anyone have any opinion about which of the current crop of wider (21 mm plus) alloy clincher rims has the most robust brake track? I guess there are three main components: thickness, durability of alloy, and height of the braking surface. I know height of the surface is not directly connected to longevity but I do like having more area with which to work. Application will be on a bad weather bike hence my query.
btompkins0112
by btompkins0112
I am currently running a build w/ Kinlin XC279s and they have worn well thus far through rain, mud, etc and look none the worse for wear. I have also had Archetypes in the past and although I didn't have them long enough to give a proper opinion, the certainty felt robust.
Stefano
by Stefano
You could also consider hard ano coatings like on ambrosio or hplus son tb14- In my experience they take a while to wear through, should extend longevity by protecting the aluminum below it for awhile
Jere
by Jere
Mr.Gib wrote:Does anyone have any opinion about which of the current crop of wider (21 mm plus) alloy clincher rims has the most robust brake track? I guess there are three main components: thickness, durability of alloy, and height of the braking surface. I know height of the surface is not directly connected to longevity but I do like having more area with which to work. Application will be on a bad weather bike hence my query.
Hi
The brake pad material you use can effect the wear
I found the kool stop orange / red do not pick up as much Alum or dirt in the braking surface.
But they do get spongy after a few high speed slow downs on Mountain passes.
JB
HillRPete
by HillRPete
If you are very concerned about wear on the brake tracks, you might as well use something like the Ambrosio Keba. Good dimensions -- 24mm wide -- and plenty durable, as a trekking rim. Of course there is a bit of a weight penalty over the more flimsy road hoops.
bm0p700f
by bm0p700f
I think the archetype is the most robust of the current wide road "race" rims. Kinlins are always a bit softer but soft brake pads help alot.
Zen Cyclery
by Zen Cyclery
The Archetype or XC279 are going to have the stoutest brake tracks. With that said I'd still take the SL23 any day over those rims for the finish and strength to weight ratio.
