It is currently Tue Feb 28, 2017 2:43 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Mon Dec 30, 2013 11:23 am
Is design with large DS beraing around freehub good or bearing wears too quickly?
http://brimages.bikeboardmedia.netdna-c ... rts011.jpg
http://kavitec.blogspot.com/
click this! http://www.youtube.com/watch?v=0m8maAO-m-w
PostPosted: Mon Dec 30, 2013 11:31 am
It's good. Spaces the bearings more widely, which is good for minimising loads. Allows a bigger bearing, which will take a higher loading (so should increase life).
Only problem is, getting to the pawl/freewheel mechanism!
PostPosted: Mon Dec 30, 2013 6:18 pm
What about new design Alchemy ORC UL or Easton?
Sam stiffnes and lower weight or less stiff hub?
For big bearing on freehub body i hear they wear out quickly - or i am wrong
PostPosted: Mon Dec 30, 2013 6:25 pm
Not familiar with either of those hubs.
But a larger bearing doing the same job should last longer. And by the looks of it, when you are pedaling the bearing won't be don't anything, as hub body and freewheel will be rotating at the same rate.
On the down side the bearing is more exposed, so you could get degreaser/chain lube/grit into the bearing more easily.
PostPosted: Thu Jan 02, 2014 2:20 pm
Both of those freehubs referred to in the link are for the same hub... The one on the left is for SRAM's XX1 11spd 10-42t cassette which requires a different mounting arrangement, dubbed 'XD' and is an open design for manufacturers to use.
PostPosted: Sat Jan 04, 2014 9:44 am
Picture i post is just for info -
Wich design is better - new like Alchemy ORC UL, Easton ECHO... or with outer freehub large bearing (older Alchemy ORC)?
PostPosted: Sat Jan 11, 2014 8:25 am
Looks like an Industry Nine hubs older hubs. I have those and they are highly reliable rear hubs!
There are no new unread posts for this topic. FS: Rapha Pro Team LS Jersey Large and Rapha Winter Windproof LS Jersey Large
nismosr
Mon Dec 05, 2016 2:24 pm
nismosr View the latest post
There are no new unread posts for this topic. Large Bike Recommendations
JoeFlan
Sun May 08, 2016 9:30 pm
Treelegs View the latest post
There are no new unread posts for this topic. Large Volume Tubulars
in Everything wheels
Curious George
7
553
Tue Apr 12, 2016 12:29 pm
audiojan View the latest post
There are no new unread posts for this topic. Looking for 2017 Spark RC (X-large)
in MTB
Lelandjt
Sat Feb 11, 2017 8:04 pm
wingguy View the latest post
There are no new unread posts for this topic. FS:Rapha winter windproof Jersey Large
nismosr
Mon Feb 13, 2017 7:58 pm
Users browsing this forum: No registered users and 3 guests
