Tubular Glue Removal
That stuff is truly nasty, and not only is it bad for you, but also your unborn children:
Human health hazards : May cause cancer. May cause heritable genetic damage. Also harmful: may cause
lung damage if swallowed. Irritating to respiratory system. Repeated exposure may
cause skin dryness or cracking. Vapours may cause drowsiness and dizziness.
Environmental hazards : Toxic to aquatic organisms, may cause long-term adverse effects in the aquatic
environment.
environment.
- HammerTime2
- Location: Wherever there's a mountain beckoning to be climbed
I haven't seen a safety data sheet for Schwalbe tubular glue remover. Is there one?
Like @Dual says... Just don't mix it with your gin and you'll be fine. Can't get Schwalbes glue remover in North America anyway, well at least not in the US. There are other adhesive removers that work. I do like to strip my rims clean for each fresh tire. I wouldn't if I had to scrape every last bit off by hand. Mechanics are pressed for time and the pros probably get new wheels before any build up of old glue becomes a problem. Acetone cuts right through nitrile gloves, but I use them and change frequently. I only use acetone for final cleaning of any residue, not for actual glue removal.
- HammerTime2
I obtained the Schwalbe tubular glue remover safety data sheet. It doesn't look as nasty as other glue removers. Any expert care to weigh in?
Schwalbe Tubular Glue Remover Safety data sheet wrote:Page 1/7
Safety data sheet
according to 1907/2006/EC, Article 31
Printing date 03.01.2012 Revision: 03.01.2012
34.0
1 Identification of the substance/mixture and of the company/undertaking
· Product identifier
· Trade name: Klebstoffentferner SRK
· Article number: B1020043
· Relevant identified uses of the substance or mixture and uses advised against
· Application of the substance / the preparation Cleaning agent/ Cleaner
· Details of the supplier of the safety data sheet
· Manufacturer/Supplier:
CTA GmbH
Industriestr. 2
D-74321 Bietigheim-Bissingen
· Further information obtainable from:
fon: ++49-(0)-7142-506-0
fax: ++49-(0)-7142-506-140
e-mail: dirk.buchholz@cta-gmbh.de
· Emergency telephone number:
Giftnotruf Berlin: fon: ++49-(0)-30-30686 790 Beratung in Deutsch und Englisch
2 Hazards identification
· Classification of the substance or mixture
· Classification according to Regulation (EC) No 1272/2008
GHS02 flame
Flam. Liq. 3 H226 Flammable liquid and vapour.
GHS07
Skin Sens. 1 H317 May cause an allergic skin reaction.
Aquatic Chronic 3 H412 Harmful to aquatic life with long lasting effects.
· Classification according to Directive 67/548/EEC or Directive 1999/45/EC
R53: May cause long-term adverse effects in the aquatic environment.
· Information concerning particular hazards for human and environment:
The product has to be labelled due to the calculation procedure of the "General Classification guideline
for preparations of the EU" in the latest valid version.
· Classification system:
The classification is according to the latest editions of the EU-lists, and extended by company and
literature data.
· Label elements
· Labelling according to EU guidelines:
Observe the general safety regulations when handling chemicals.
The product has been classified and marked in accordance with EU Directives / Ordinance on Hazardous
Materials.
· Risk phrases:
53 May cause long-term adverse effects in the aquatic environment.
· Safety phrases:
29/56 Do not empty into drains, dispose of this material and its container at hazardous or special waste
collection point.
(Contd. on page 2)
GB
Page 2/7
Safety data sheet
(Contd. of page 1)
34.0
· Other hazards
· Results of PBT and vPvB assessment
· PBT: Not applicable.
· vPvB: Not applicable.
3 Composition/information on ingredients
· Chemical characterization: Mixtures
· Description: Mixture of substances listed below with nonhazardous additions.
· Dangerous components:
CAS: 90622-58-5
EC number: 920-901-0
Reg.nr.: 01-2119456810-40
Alkane, C11-15-iso-
Xn R65
R66
Asp. Tox. 1, H304
25-50%
CAS: 90622-57-4
EC number: 918-167-1
Reg.nr.: 01-2119472146-39
Alkane, (C9-C12)-Iso-
Xn R65
R53-66
Asp. Tox. 1, H304; Aquatic Chronic 4, H413
25-50%
CAS: 8028-48-6
EINECS: 232-433-8
Reg.nr.: 01-2119493353-35-0003
Orange, süß, Extrakt
Xn R65; Xi R38; Xi R43; N R50/53
R10
Flam. Liq. 3, H226; Asp. Tox. 1, H304; Aquatic
Acute 1, H400; Aquatic Chronic 1, H410; Skin Irrit. 2,
H315; Skin Sens. 1, H317
£ 2.5%
· Additional information: For the wording of the listed risk phrases refer to section 16.
4 First aid measures
· Description of first aid measures
· After inhalation: Supply fresh air; consult doctor in case of complaints.
· After skin contact: Generally the product does not irritate the skin.
· After eye contact: Rinse opened eye for several minutes under running water.
· After swallowing: If symptoms persist consult doctor.
· Information for doctor:
· Most important symptoms and effects, both acute and delayed
No further relevant information available.
· Indication of any immediate medical attention and special treatment needed
5 Firefighting measures
· Extinguishing media
· Suitable extinguishing agents:
CO2, powder or water spray. Fight larger fires with water spray or alcohol resistant foam.
· Special hazards arising from the substance or mixture No further relevant information available.
· Advice for firefighters
· Protective equipment: No special measures required.
GB
(Contd. on page 3)
Page 3/7
Safety data sheet
(Contd. of page 2)
34.0
6 Accidental release measures
· Personal precautions, protective equipment and emergency procedures Not required.
· Environmental precautions:
Do not allow product to reach sewage system or any water course.
Inform respective authorities in case of seepage into water course or sewage system.
Do not allow to enter sewers/ surface or ground water.
· Methods and material for containment and cleaning up:
Absorb with liquid-binding material (sand, diatomite, acid binders, universal binders, sawdust).
· Reference to other sections
See Section 7 for information on safe handling.
See Section 8 for information on personal protection equipment.
See Section 13 for disposal information.
7 Handling and storage
· Handling:
· Precautions for safe handling Keep receptacles tightly sealed.
· Information about fire - and explosion protection: No special measures required.
· Conditions for safe storage, including any incompatibilities
· Storage:
· Requirements to be met by storerooms and receptacles: No special requirements.
· Information about storage in one common storage facility: Not required.
· Further information about storage conditions: None.
· Specific end use(s) No further relevant information available.
8 Exposure controls/personal protection
· Additional information about design of technical facilities: No further data; see item 7.
· Control parameters
· Ingredients with limit values that require monitoring at the workplace:
The product does not contain any relevant quantities of materials with critical values that have to be
monitored at the workplace.
· Additional information: The lists valid during the making were used as basis.
· Exposure controls
· Personal protective equipment:
· General protective and hygienic measures: Wash hands before breaks and at the end of work.
· Respiratory protection: Not required.
· Protection of hands:
The glove material has to be impermeable and resistant to the product/ the substance/ the preparation.
Selection of the glove material on consideration of the penetration times, rates of diffusion and the
degradation
· Material of gloves
Nitrile rubber, NBR
Recommended thickness of the material: ³ 0.5 mm
· Penetration time of glove material
The exact break trough time has to be found out by the manufacturer of the protective gloves and has to
be observed.
(Contd. on page 4)
GB
Page 4/7
Safety data sheet
(Contd. of page 3)
34.0
· Eye protection: Goggles recommended during refilling
9 Physical and chemical properties
· Information on basic physical and chemical properties
· General Information
· Appearance:
Form: Fluid
Colour: Blue
· Odour: Characteristic
· Odour threshold: Not determined.
· pH-value: Not determined.
· Change in condition
Melting point/Melting range: Undetermined.
Boiling point/Boiling range: 175°C
· Flash point: 56°C
· Flammability (solid, gaseous): Not applicable.
· Ignition temperature: 210°C
· Decomposition temperature: Not determined.
· Self-igniting: Product is not selfigniting.
· Danger of explosion: Product does not present an explosion hazard.
· Explosion limits:
Lower: 0.5 Vol %
Upper: 6.5 Vol %
· Vapour pressure at 20°C: 2 hPa
· Density at 20°C: 0.79 g/cm³
· Relative density Not determined.
· Vapour density Not determined.
· Evaporation rate Not determined.
· Solubility in / Miscibility with
water: Not miscible or difficult to mix.
· Segregation coefficient (n-octanol/water): Not determined.
· Viscosity:
Dynamic at 20°C: 1100 mPas
Kinematic: Not determined.
· Other information No further relevant information available.
10 Stability and reactivity
· Reactivity
· Chemical stability
· Thermal decomposition / conditions to be avoided:
No decomposition if used according to specifications.
· Possibility of hazardous reactions No dangerous reactions known.
(Contd. on page 5)
GB
Page 5/7
Safety data sheet
(Contd. of page 4)
34.0
· Conditions to avoid No further relevant information available.
· Incompatible materials: No further relevant information available.
· Hazardous decomposition products: No dangerous decomposition products known.
11 Toxicological information
· Information on toxicological effects
· Acute toxicity:
· Primary irritant effect:
· on the skin: No irritant effect.
· on the eye: No irritating effect.
· Sensitization: No sensitizing effects known.
12 Ecological information
· Toxicity
· Aquatic toxicity: No further relevant information available.
· Persistence and degradability No further relevant information available.
· Behaviour in environmental systems:
· Bioaccumulative potential No further relevant information available.
· Mobility in soil No further relevant information available.
· Additional ecological information:
· General notes:
Water hazard class 1 (German Regulation) (Self-assessment): slightly hazardous for water
Do not allow undiluted product or large quantities of it to reach ground water, water course or sewage
system.
· Other adverse effects No further relevant information available.
13 Disposal considerations
· Waste treatment methods
· Recommendation
Must not be disposed together with household garbage. Do not allow product to reach sewage system.
· Uncleaned packaging:
· Recommendation: Disposal must be made according to official regulations.
14 Transport information
· UN-Number
· ADR, IMDG, IATA UN1993
· UN proper shipping name
· ADR 1993 FLAMMABLE LIQUID, N.O.S. (Orange, süß,
Extrakt), special provision 640E
· IMDG, IATA FLAMMABLE LIQUID, N.O.S. (Orange, süß, Extrakt)
(Contd. on page 6)
GB
Page 6/7
Safety data sheet
(Contd. of page 5)
34.0
· Transport hazard class(es)
· ADR
· Class 3 (F1) Flammable liquids.
· Label 3
· IMDG, IATA
· Class 3 Flammable liquids.
· Label 3
· Packing group
· ADR, IMDG, IATA III
· Environmental hazards:
· Marine pollutant: No
· Special precautions for user Warning: Flammable liquids.
· Danger code (Kemler): 30
· EMS Number: F-E,S-E
· Transport in bulk according to Annex II of
MARPOL73/78 and the IBC Code Not applicable.
· Transport/Additional information:
· ADR
· Tunnel restriction code D/E
· UN "Model Regulation": UN1993, FLAMMABLE LIQUID, N.O.S. (Orange, süß,
Extrakt), special provision 640E, 3, III
15 Regulatory information
· Chemical safety assessment: A Chemical Safety Assessment has not been carried out.
16 Other information
This information is based on our present knowledge. However, this shall not constitute a guarantee for
any specific product features and shall not establish a legally valid contractual relationship.
· Relevant phrases
H304 May be fatal if swallowed and enters airways.
H315 Causes skin irritation.
H400 Very toxic to aquatic life.
H410 Very toxic to aquatic life with long lasting effects.
(Contd. on page 7)
GB
Page 7/7
Safety data sheet
(Contd. of page 6)
34.0
H413 May cause long lasting harmful effects to aquatic life.
R10 Flammable.
R38 Irritating to skin.
R43 May cause sensitisation by skin contact.
R50/53 Very toxic to aquatic organisms, may cause long-term adverse effects in the aquatic
environment.
R53 May cause long-term adverse effects in the aquatic environment.
R65 Harmful: may cause lung damage if swallowed.
R66 Repeated exposure may cause skin dryness or cracking.
· Department issuing MSDS: Abteilung Produktsicherheit
· Contact: Dr. Dirk Buchholz
· Abbreviations and acronyms:
ADR: Accord européen sur le transport des marchandises dangereuses par Route (European Agreement concerning the
International Carriage of Dangerous Goods by Road)
RID: Règlement international concernant le transport des marchandises dangereuses par chemin de fer (Regulations Concerning
the International Transport of Dangerous Goods by Rail)
IMDG: International Maritime Code for Dangerous Goods
IATA: International Air Transport Association
ICAO: International Civil Aviation Organization
GHS: Globally Harmonized System of Classification and Labelling of Chemicals
GB
i'd never found the msds online, so nice to see the content now
Alkane, C11-15-iso- Alkane, (C9-C12)-Iso- as long as you're not snorting it, eating it or rubbing it all over, it's not going to hurt you, especially as it's mixed into the gel, just wear gloves, use in a well ventilated room, and dispose of responsibly like any you would old oil, paraffin etc.
Orange, süß, Extrakt probably the oil from peel
overall seems pretty innocuous vs. some of the alternatives
Hello,
Schwalbe glue remover is not nastier than goo off or others more volatile solvents if you see from the application. IMO it is much safer. It took me less than 3 minutes to apply it into a rim then come back for 5 minutes wipe after 30 minutes or use pressure wash. This is much better than goo off where I have to keep applying and rubbing the glue. The exposure to scwhalbe glue remover is way less than if I use other products. I am not sure whats the formula but I smell a bit of citrus de-greaser rather than any petroleum products. If you guys in NA, PM me, I know where to get it.
Hi,
That's what I like about it. You brush it on, let it do the work for you, then you scrape all the stuff off and that's that.
Ciao,
Ciao,
nfecyle wrote:Hello,
... If you guys in NA, PM me, I know where to get it.
Why don't you just post where we, in North America, can get it right here. I've been using a product for adhesive removal including mastiks from Kleen Strip, but I'd like to be able to try the Scwalbe stuff to see if it's any different. Sounds like it might be less harsh.
Calnago wrote:nfecyle wrote:Hello,
Hi,
If it's not against forum rule, I get it from here and I am not affiliated:
http://www.tiremaniacs.com/schwalbe_tub ... tails.aspx
What is the point of removing all of the old glue? Large gobs for sure, but the new glue will reactivate the old adhesive. I use a dull knife to remove the large chunks.
For what it's worth, the pros don't seem to stress too much about some old glue residing on the rim.
http://www.youtube.com/watch?v=_Rjb-aWnbiY
How awesome is the mustard squeeze bottle glue application!
- HammerTime2
If you're changing to a different (formulation of) glue - that would be one reason.petepeterson wrote:What is the point of removing all of the old glue?
I ordered some of that schwalbe remover, will see how it goes next time.
I normally use Goof-Off. Get an old rag/throw away and get it soaked real well, and just start going over the rim..keep turning the rag inside out due to adhesive coming off. Doesn't take but 10-15 minutes and maybe 2 small micro fiber rags to get it perfectly clean. Then use some acetone to get it really spotless, clean up any residue.
Just have ventilation and some gloves.
