It is currently Tue Jan 23, 2018 3:22 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: New Vittoria Tubular?
PostPosted: Fri Dec 20, 2013 10:00 pm
Just received next years supply of tubulars, and noticed that they are now called Vittoria Corsa CX III, Pro Series. Evo CX II is history I reckon. The new rubber compound is called ISOgrip.
I can't find much about this new tire. Hoping for the best!
PostPosted: Fri Dec 20, 2013 10:54 pm
Interesting. Love the Vittoria Corsa Evo CX II tubulars. Sounds like they just got better!
PostPosted: Sat Dec 21, 2013 5:06 pm
Couple of observations;
* Weight is 252grams @ 23mm wide.
* The valve stem is brass, and it looks like it cannot be removed. If true would be a real bummer.
PostPosted: Sat Dec 21, 2013 7:41 pm
I bought one earlier in the year. Mine also had the brass stem which appears to be non-removeable which sucks since the proper length Vittoria stems I bought a year earlier are now too long.
PostPosted: Sun Dec 22, 2013 9:39 pm
aint this one?
http://www.totalcycling.com/a-z/tires/t ... 0_iso.html
this is diferent from the CX II who has the intire valve stem removed, it's back to valve core remove stem.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
PostPosted: Mon Dec 23, 2013 12:09 am
Yes, core is removable, which means you will be able to insert sealant for small puncture repair out on the road. Sorry, I'm a bit late to the party.
Looking forward to trying this new tire compound!
There are no new unread posts for this topic. Vittoria Corsa Control G+ Tubular
Wookski
Tue Jan 23, 2018 2:11 pm
elfuinha View the latest post
There are no new unread posts for this topic. Vittoria Corsa G+ tubular leaking air from sidewalls...
3Pio
Mon Oct 30, 2017 8:00 pm
3Pio View the latest post
There are no new unread posts for this topic. Vittoria Corsa speed Graphene tubular
in Everything wheels
bikebreak
Tue Mar 21, 2017 12:04 am
UpFromOne View the latest post
There are no new unread posts for this topic. Vittoria Corsa Elite tubular tire
3Pio
22
1629
Mon Oct 23, 2017 9:19 am
themidge View the latest post
There are no new unread posts for this topic. Attachment(s) Handbuilt tubular wheelset 38mm 1175gr + Vittoria Corsa tubulars 25mm
SLight
Fri Nov 24, 2017 5:41 pm
SLight View the latest post
Users browsing this forum: Baidu [Spider], MayhemSWE, proudCAAD12 and 6 guests
