It is currently Sun Jan 21, 2018 6:19 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: Fri Dec 06, 2013 9:49 pm
I have both.
Escapes 28/28 laced to Chris King and Ambrosio Crono, also 28/28 but to DA hubs.
The escapes are a stiffer wheel but I have to say I think I prefer the Crono's, the feel / feedback through the wheel is fantastic. Breaking is fine too.
Last I heard the escapes are out of production so it will be hard to get stock unless you know a shop with some already.
PostPosted: Sun Dec 08, 2013 5:31 pm
Has the OP thought about the KinLin TB25? They're heavier than the 2 listed but much stronger and more suitable for low spoke counts.
Also the BHS rim? http://www.bikehubstore.com/C472w-p/tb415.htm
LouisN wrote:
And they're very tough to find outside AUS below 28h.
All of the drillings except for the 28h are in stock on the Velocity website. Some of their products have been harder to get because they stopped production while moving from Aus to USA.
I think a few of the extrusions have changed slightly during this process and maybe they've got new part numbers or something along those lines? :noidea:
PostPosted: Mon Dec 09, 2013 12:40 am
I recently built a set of aluminium tubular wheels for crit racing purposes. Wasn't aiming for low weight (as in climbing wheelset), wanted something solid and cheap. Used the TB25 rims, and have been pleased so far. Weights for rims were 433 and 422 grams. Not super light-weight, but as jooo just mentioned I would have no reservations using them in low spoke-count wheels (I'm using 24/28 on Novatec hubs with DT revolution spokes, brass nipples).
In comparison, I've used Crono F20 in a 28hole build on DA7700 hubs, and had lots of issues with wheels going out of true (racing crits, 73kg).
Storck Fenomalist 6.8kg
PostPosted: Mon Dec 09, 2013 12:44 pm
Thanks jooo, I'd only heard the first part and losing them completely would have been a real shame. I'll keep an eye out for the new ones.
PostPosted: Mon Dec 09, 2013 6:37 pm
I built a set of alloy tubulars with the BHS TB415w rims, SLF71w front hub, UL190 rear hub and Mac Aero360 spokes that came in at 1295g. They've been surprisingly stiff, but I'm 59kg.
PostPosted: Mon Dec 09, 2013 6:52 pm
@Wookie- Where did you buy the macaero spokes from? I've only found one shop in Germany, and they didn't have a very big selection of lengths... Also, what was your experience with the build, were they pretty consistent in length and quality?
Sorry for the OT...
Anyways, I built an aluminum tubular wheelset on BHS hubs recently, used some older matrix branded rims... at 28/28 and 74kg, they worked pretty well for a couple of seasons. Wouldn't have gone much lower though, 20/24 sounds flexy with such light weight rims
PostPosted: Mon Dec 09, 2013 8:14 pm
I have bought the MacAero spokes, 424s and 360s, on Ebay from seller Good886. My experience with them has been really positive, lengths are consistent, quality is good and you can get both even and odd lengths. The only thing that is a bit annoying is that the round section really varies in length depending on overall spoke length. Some lengths have a very short round section and on others it is quite long. All three of my recent personal wheelsets I've built with Mac spokes and I've had no issues. For the price I don't see myself going back to CX-Rays.
PostPosted: Mon Dec 09, 2013 8:28 pm
+1 on both Good886 and CN Mac spokes.
Also the one to go to for fair prices on Kinlin rims.
PostPosted: Mon Dec 09, 2013 10:29 pm
490g nemesis is the weight of my rims. Alloy nipples have given no issues in all the wheels builds I have done. no breakages. I use them no most of my personal wheelsets even my winter wheels and have no issues.
28H Chrono rims are for sub 50kg riders. 32H chrono's need to be build with Race spokes or similar and even then sub 75 kg riders. I would not ride them at 80 kg.
Escapes built with Laser and DA hubs would be my ideal choice in 24F/28R or 28F/28R. Kinlin's are not a bad choice but are heavier.
www.thecycleclinic.co.uk
PostPosted: Tue Dec 10, 2013 11:20 pm
Good to hear about the mac spokes! I'll definitely use him when I build up my carbon rims this winter :) I bet the reason the round part is different lengths is that they only make the forgings for the spokes in even lengths with a long round section, then cut/ thread the odd lengths off from that. Saves a bunch of money and lets you stock fewer lengths.
I too vote for alloy nipples- if you build the wheels right, you shouldn't have to true them anyways after the initial few miles, so rounding off has never been a problem for me. There are some interesting new designs with hexagonal heads/ stuff that make that less of a concern if you were worried though.
PostPosted: Tue Dec 10, 2013 11:58 pm
Wheels needing truing after a few miles that shouldn't happen either.
PostPosted: Wed Dec 11, 2013 2:30 am
I usually never need to true at all after stress relieving, but I do live in Michigan, and things happen...
PostPosted: Wed Dec 11, 2013 8:48 pm
Wookie, what tires are you running? I'm curious if a the rim bed profile is more conducive to road tires than that of the Major Tom is reported to be. Thanks!
PostPosted: Thu Dec 12, 2013 3:09 pm
I just noticed that your rear wheel got a 2:1 rear spoke ratio and all this is laced with 1 cross head in...
That's the first time i see that. That's a bit strange, it seems to me that it should not be ideal for power transfer.
My 1998 Trek 5220 paint stripped 6.41Kg
PostPosted: Thu Dec 12, 2013 7:47 pm
Teleguy, The tires are 25mm Vittoria Corsa SCs. I've been happy with the fit on the rims. I removed the rear tire due to a puncture and it was the most difficult tire I've removed. Anything smaller is unlikely to work well though, maybe a 24mm tire would work, but it would be pushing it.
Djay, you are right about the lacing pattern. It was an experiment, I was worried the low profile rim with a low spoke count and very light spokes would turn out noodley so I was trying to get the widest bracing angle I could. I was more concerned with lateral stiffness when getting out of the saddle on very steep grades than with power transfer. The wheels turned out to be more laterally stiff than my 2x both sides XR300s and wind up hasn't been an issue for me, but I'm not putting out a ton of watts (that said, I did manage to take a Strava KOM off the current US national champ on these wheels :D ). Knowing what I know now about how this combination performs I would probably lace the DS 2x in the future, but this met my needs.
There are no new unread posts for this topic. Climbing wheelset
in Everything wheels
chalkie1000
18
3109
Tue Jun 27, 2017 7:47 am
robertbb View the latest post
There are no new unread posts for this topic. Uber lightweight, yet durable and practical tubular climbing wheels?
Noctiluxx
7
747
Sun Dec 10, 2017 6:27 pm
RyanH View the latest post
There are no new unread posts for this topic. Corima Winium 25mm carbon weight weenie climbing rim, 24h tubular NEW CHEAP
sussexhills
Mon Nov 06, 2017 7:27 pm
sussexhills View the latest post
There are no new unread posts for this topic. Light aluminum wheelset suggestions for Cervelo R3 or R5
ihaveabikeproblem
Fri Nov 24, 2017 5:33 pm
slowK View the latest post
ihaveabikeproblem
10
1282
Sat Nov 25, 2017 9:18 pm
eaglejackson View the latest post
Users browsing this forum: Klaster1, proudCAAD12 and 3 guests
cron
