It is currently Mon Jan 22, 2018 3:27 pm
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: Help with spoke count
PostPosted: Wed Nov 27, 2013 4:24 pm
Hi,
Ordering a wheelset today: White Industries T11, brass nipples, CX-Ray spokes, and Archetype rims. I weigh 195lbs and race at that weight. Should I go 24/28 (24 radially spoke/28 -2x) or 28/32? (2x/3x).
Thanks
PostPosted: Wed Nov 27, 2013 4:49 pm
24/28
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Wed Nov 27, 2013 10:22 pm
I would go 24/28 too, but remember to use spoke washers, so you donĀ“t stress the hub flanges when lasing radial.
 Post subject:
PostPosted: Thu Nov 28, 2013 12:16 am
PostPosted: Thu Nov 28, 2013 6:13 pm
20-28 or 24-32 depending on how hard you are on wheels and how much you value stiffness.
formerly rruff...
PostPosted: Thu Nov 28, 2013 7:42 pm
Thanks. 24 radially laced or cross. I will be going 32-3x for the rear.
PostPosted: Fri Nov 29, 2013 1:34 am
Either radial or 2x would be fine on the front.
formerly rruff...
PostPosted: Fri Nov 29, 2013 2:05 am
Wonder if I can ask the same question?
I'm 60kg +- 1kg. Looking at building up some Chinese carbon rims. Was thinking 16 front and rear which is the same as my training wheels.
PostPosted: Sat Nov 30, 2013 6:48 am
Which rims.
formerly rruff...
PostPosted: Sat Nov 30, 2013 2:45 pm
Wide profile 50-60mm deep rims.
PostPosted: Sat Nov 30, 2013 4:46 pm
I haven't noticed any cheap rims that come in 16h. 20h is the smallest.
The hubs will also matter, but I wouldn't spec 16h rear unless you had a track record of being very light on your wheels. Plus for equal strength and stiffness the rear wheel needs more spokes than the front on a road bike... just looks wrong to me to have them the same.
formerly rruff...
There are no new unread posts for this topic. Are all cogs of the same tooth count the same diameter?
Shrike
Sat May 20, 2017 8:20 pm
2lo8 View the latest post
This topic is locked, you cannot edit posts or make further replies. [removed - not sufficient post count]
Bream
Tue Dec 12, 2017 12:42 pm
Bream View the latest post
There are no new unread posts for this topic. Attachment(s) Deleted - post count - please read the rules
tfayet
Thu Dec 28, 2017 9:25 am
tfayet View the latest post
There are no new unread posts for this topic. post deleted, post count.
izza
Sun Oct 22, 2017 7:45 pm
izza View the latest post
There are no new unread posts for this topic. ENVE 4.5 SES - Spoke woes...
in Everything wheels
clipsed
Wed Nov 08, 2017 1:28 pm
ergott View the latest post
Users browsing this forum: Gutsyfungus, joec and 4 guests
