It is currently Mon Jan 22, 2018 1:31 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Sun Dec 01, 2013 11:08 pm
I don't have the rims yet, but I received the tires. Some data. The FMB 25s are 4.7mm larger in DIA than the 22.5s. They are 6mm larger in DIA than the old Vittoria Cronos. Note my son could pass Jr rollout with a 53X12 with the Vittoria. The FMBs vary in width/height based on location of measurement by .7mm. The Veloflex Record vary little..
Below FMB 22.5 100psi
Below FMB 25 100psi
320TPI (current) Vittoria
From Left to right - FMB 22.5, FMB 25 and Veloflex Record 22
"Old" 290TPI Vittoria
PostPosted: Sat Dec 07, 2013 11:50 am
I have zipp 202s, I run 23s on them at the moment but will 25s run fine on them or will they be too wide a tubular?
PostPosted: Thu Jan 16, 2014 8:58 pm
I have a set of 23mm HED Belgium tubular rims on order. These are my first set of tubulars. I notice a lot of tubular tires come in 22mm sizes. Is it safe to mount a 22mm tubular on a 23mm rim? Or should I look for 23mm or greater?
Also, for using tubulars on a trainer; since there is no trainer specific tubular tire on the market (at least I haven't found one), is it advisable to just buy a cheap tubular for the rear wheel (eg. Conti Giro or Vittoria Rally) to use with an indoor trainer? Then take it off in the spring and put on something better?
Thanks.
 Post subject:
PostPosted: Thu Jan 16, 2014 9:17 pm
PostPosted: Thu Jan 16, 2014 9:41 pm
I would continue to use my clinchers on the trainer, but the tubular wheels are being built with a Powertap hub on the rear wheel, so I'd like to use that on the trainer.
PostPosted: Fri Jan 17, 2014 12:16 am
Trainer is another use for tubs that are not good enough for road use any longer. Your call as to what 'not good enough' means eg Stans etc sealant used for punctured, too worn, too cut-up
Less is more.
PostPosted: Mon Jan 20, 2014 10:31 am
No problem, 202s get used in CX too.
PostPosted: Mon Jan 20, 2014 1:41 pm
Thank you
There are no new unread posts for this topic. Tire Size reccommendation
bobbyfox66
Mon Apr 03, 2017 12:29 pm
hongsj View the latest post
There are no new unread posts for this topic. Vittoria Corsa Elite tubular tire
3Pio
22
1626
Mon Oct 23, 2017 9:19 am
themidge View the latest post
There are no new unread posts for this topic. Seatpost creaking in frame (and ideal insertion)
Alexandrumarian
9
671
Sun Oct 08, 2017 7:07 pm
Alexandrumarian View the latest post
There are no new unread posts for this topic. Tire direction MTB
in MTB
jorisee01
12
1392
Fri Jul 28, 2017 2:00 am
CycloTron View the latest post
There are no new unread posts for this topic. Tire companies
Mtek
Sun Jul 30, 2017 4:41 am
Mtek View the latest post
Users browsing this forum: Bing [Bot] and 5 guests
