It is currently Mon Jan 22, 2018 7:28 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
PostPosted: Mon Nov 25, 2013 4:27 am
For tubular glue on only, what is the ideal tire width vs. rim width ratio - 1:1? What is too narrow? Can the tire be narrower than the rim? Feels like a 22 wide tire would be good on a 22 wide rim. There are 25mm rims - should they have 25mm tires? Can a 20mm rim have a 25 mm tire?
I love the Veloflex Rocord 28 (22mm), but seeing these FMB 25 silks that look good, although heavier. The rim coming is 25mm.
Opinions please.
PostPosted: Mon Nov 25, 2013 3:21 pm
Ideal for what? Discussing rim width in a vacuum isn't helpful. For ride quality, I prefer shallow, box rims. For aerodynamics, the shape of the rim is more important than simply making the rim wider. Rims from Zipp, Hed, Enve et al are all 25mm and wider, but it's the transition from tire to rim sidewall that's important. Rim depth also needs to be considered.
www.ergottwheels.com
PostPosted: Mon Nov 25, 2013 3:43 pm
Racing - Crit and road.
deleted the quote.
PostPosted: Mon Nov 25, 2013 4:43 pm
Keep in mind rim width doesn't effect a tubular tire like a clincher. The tubular tire will remain relatively the same regardless of the rim it's glued onto.
PostPosted: Mon Nov 25, 2013 6:55 pm
I just ordered the FMB competition CX silk in 22.5 (told they are more like 23) and the 25 so I'll mount on the new rim without glue and see.
no need to use the quote function. you are writing a reply. ;)
PostPosted: Tue Nov 26, 2013 1:55 pm
@ergott, well, if you run a really narrow (18 or 19mm) TT or track-type tire on a wider rim, you may have a problem with getting a really good glue bond to the outside edges of the basetape, which is a crucial part of a secure glue job. Same goes for running a 'conventional'-width rim and a wide (30 or 32mm) 'cross tire, but at least you can run 'Belgian' tape and it seems to work just fine.
@Zorro, are you running the FMB's on a set of deep Hed rims? If so, you should be fine. The 25mm tires will work great on the back and should protect you from pinch-flatting with the deeper rim. The 22mm up-front works just fine with those rims.
PostPosted: Tue Nov 26, 2013 3:04 pm
I would be scared of running a 20-21 mm tub on a deep channel 25 mm wide rim.
Don't know if it can be dangerous, if the rim can touch asphalt on high speed 90° turns in crits...
Louis :)
PostPosted: Wed Nov 27, 2013 1:16 am
These are Mercury M5T - 25 wide. My kid is < 140 # and has ridden OLD Nibble FLYs and Easton EC90s with Veloflex Record 22 - about 120-130 PSI and most races are under 100K. As he is racing longer, and we need new wheels the Mercury wheels look good. They are supposed to be stiffer too for sprints - which matter, and pretty aero, which also matters for his type of riding. The whole 25mm does give less tire selection and they are heavier - tire and rim.
Its all ordered now - cc is charged (kicked in the fraud warning system).
I'll post pictures of the 22.5 and 25 mounted (unglued) when they get here.
PostPosted: Wed Nov 27, 2013 2:36 am
Hmmm. I havent riddent those wheels, but saw them up-close at ToC last season. The look solid to me.
I am a bit lighter than your boy, but would still not recommend running the tires that hard. I would recommend 100/110 (front/rear) for road racing and less if the conditions are wet.
PostPosted: Wed Nov 27, 2013 5:26 am
From what I've read - lower pressure unless you're Spanish. I guess the 130# Spanish riders like it at 130psi.
My kid is trying to learn Spanish - maybe the pressure will help. I will likely run them higher because he notices it and requests it.
http://velonews.competitor.com/2012/05/ ... ire_218011
PostPosted: Wed Nov 27, 2013 6:34 am
Might explain why Euskaltel are so poor at keeping their bikes upright...
VeloKicks
The Gram
The Men of Steel
PostPosted: Wed Nov 27, 2013 7:01 pm
Here he was 65lbs, 8 years old in the picture below. Tubulars were at about 65 psi. As these were Tufos, 65 psi and flat feel about the same.
We went to Vittoria Crono EVO CS for about 5 years, inflated to 100, then the Veloflex Record 22 for the past 2 years running @ 120+
PostPosted: Thu Nov 28, 2013 1:55 pm
Yeah, 130+ psi in a tubular makes no sense. You are doing all that work to get a fast, supple tire. For a light rider, there is no reason (i.e., to prevent the tire from bottoming-out on the rim and risking a pinch-flat) to run them that hard. That goes double for a high-volume rear. You can run 30 psi less without materially increasing the risk of a pinch-flat and have the benefit of better traction, better comfort and a faster tire.
Great pic. My boy will be turning 6 soon and he will fit 'proper' wheels soon. What bike is that?
PostPosted: Fri Nov 29, 2013 2:47 pm
That was an eBay Leader frame with parts from the discard bin. The hardest thing to find will be narrow HBs and Short cranks and short reach brakes. I think those were 155 as I recall.
PostPosted: Fri Nov 29, 2013 3:22 pm
Are they 25mm wide at the brake track, or 25mm at widest point?
I've only seen a handful of the modern wide tubs, but they were all bulged below the brake track. Or tapered out from the tyre channel.
So the bit where you glue is still only around 19/20/21mm wide.
There are no new unread posts for this topic. Tire Size reccommendation
bobbyfox66
Mon Apr 03, 2017 12:29 pm
hongsj View the latest post
There are no new unread posts for this topic. Vittoria Corsa Elite tubular tire
3Pio
22
1627
Mon Oct 23, 2017 9:19 am
themidge View the latest post
There are no new unread posts for this topic. Seatpost creaking in frame (and ideal insertion)
Alexandrumarian
9
671
Sun Oct 08, 2017 7:07 pm
Alexandrumarian View the latest post
There are no new unread posts for this topic. Tire companies
Mtek
Sun Jul 30, 2017 4:41 am
Mtek View the latest post
There are no new unread posts for this topic. Tire direction MTB
in MTB
jorisee01
12
1392
Fri Jul 28, 2017 2:00 am
CycloTron View the latest post
Users browsing this forum: No registered users and 3 guests
