It is currently Wed Apr 26, 2017 5:13 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Thu Oct 10, 2013 9:51 am
Hi There,
I'm looking to buy a set of carbon clinchers.
I'm 6'4 and around 105 kgs
I ride around 400 kms a week on (mix of hills and flats)
Based on my research it looks like the ENVE 3.4s on Chris King R45s or the DT Swiss 180s would be good.
Two questions that I'd value your point of view on:
1. Am I too heavy to be riding on carbon clinchers?
2. If not, would you go for the CKs or the DT Swiss Hubs?
Thanks kindly,
J
PostPosted: Thu Oct 10, 2013 2:06 pm
Exactly same height and used to be 113. Now 95 and still falling quick
1. yep. (imo and experince with carbon tubs)
2. No answer unless you like burning money. Go on a holiday or take family somewhere special.
Cheap ass fulcrum 5's or 7's will see you through till your down a bit, and will help you get there!
Sorry if this is not the answer your looking for, but spending a *f##k** massive shiteload of cash to save 200g on a pair of wheels will not make you go any faster up the hills. Ride lots - drink less, smash all the puny dudes into the ground on the flats and in the wind on your cheap ass wheels. It's called weight training. When you get down to 85kg buy a pair of carbon tubs and pretend to be a racer.
Carbon wheels will look flash on your bike in a photo but thats all.
PostPosted: Thu Oct 10, 2013 2:15 pm
+1....nothing worse than looking out of place on your own bike IMO.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Thu Oct 10, 2013 2:18 pm
Jaimesl wrote:
Hi There,
Thanks kindly,
J
Take a look at these in the 24/28 configuration. Stated weight limit is 250 lbs which should have you covered.
http://www.boydcycling.com/products/60mm-clincher.html" onclick="window.open(this.href);return false;
PostPosted: Thu Oct 10, 2013 8:22 pm
the lightweight gipfelsturm have a weight limit of 110kg, but i suppose this includes the frame and components...so you might be a bit over it.
http://www.youtube.com/watch?v=D4XxCZagAjk
PostPosted: Thu Oct 10, 2013 9:36 pm
You're not too heavy for carbon clinchers. The Enves could easily handle your weight even in the 20/24 drilling that the SES series come in.
Concerning the hubs both the Kings and DTs are great options. The Kings have the bling factor (name, colors, etc) where as the DTs are much easier to service.
http://www.zencyclery.com
PostPosted: Thu Oct 10, 2013 10:24 pm
Thanks for all the replies.
Appreciated.
J
PostPosted: Fri Oct 11, 2013 10:43 pm
Sorry for using this thread but it seemed somewhat useful for my question.
I see several sites claiming a weight of 1250g for the ENVE ses 3.4 clincher, like here http://www.merlincycles.com/bike-shop/wheels/road-wheels/factory-road-wheels/enve-ses-34-clincher-wheelset-ck-hub-plus-free-tyres.html
The rims alone is claimed to weigh a total of 885g from several sources, and the Chris King hubs which I believe must be the R-45 is 317g (anyway its the lightest from CK). Thats 1202g, so now you have approx 48g for spokes and nipples. Explain it to me, what am I missing?
I also have a seller here in Norway who is claiming a weight of 1245g for the clincher version with CK R-45 hubs.
Also bikeradar claims a weight in this range (1277g) with R-45, http://www.bikeradar.com/gear/category/components/wheel-sets/product/review-smart-enve-system-34-wheelset-12-45763/
So I guess it comes down to rim weight, checking fairwheelbikes the weight for both rims supports my earlier statement (890g there).
FWIW all wheels "checked" has 20/24 spokes
Im just a big ? now
Really want them, but want to save some grams with new wheels too :mrgreen:
PostPosted: Sat Oct 12, 2013 2:46 am
Im just a big ? now
Bikeradar's review is of the tubular set since that's what was released first and the clincher version came out afterwards. Nonetheless, it's still interesting that their measured weight (1,277g) exceeded Enve's quoted variation of +/- 2%: their specified weight for the R45 3.4 set is 1320g. Merlin cycles is erroneously quoting the tubular weight for their clincher set.
You can get a rough estimate of what a build would weigh using wheelbuilder's calculator. It's not completely spot on, but it's close enough to get an idea: http://www.wheelbuilder.com/wheel-weigh ... lator.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Sat Oct 12, 2013 3:08 am
Madfibers have NO weight limit, I have seen them used on tandems
PostPosted: Sat Oct 12, 2013 7:22 am
You can get a rough estimate of what a build would weigh using wheelbuilder's calculator. It's not completely spot on, but it's close enough to get an idea: http://www.wheelbuilder.com/wheel-weigh ... lator.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Thanks for the answer:)
Yes Ive used that calculator and that gives me a total weight of 1407g with sapim CX-ray spokes. So I guess it comes to what the actual weight of these are, have someone weighed them themselves?
And what other carbon clinchers with a 30-50mm profile is out there, that maybe weighs in between these 3.4 R45 and the LW Meilenstein C that is 1230g? Of course we have the Zipp 202 firecrest at 1375g..
PostPosted: Sat Oct 12, 2013 1:57 pm
I have my 3.4 clinchers with Alchemy ELF/ORC-UL coming in on tues, when it shows up I could post the weights. As for the stock weight I can't remember the top of my head, but the specs on enve's site sound about right for the 3.4 clincher DT240s stock weight.
PostPosted: Sat Oct 12, 2013 6:02 pm
First of all, you aren't too heavy for some carbon clinchers. Reynolds has no specific weight limit, but they do recommend that you ride 24-spoke rear wheels to hand the weight. I tip the scales around your size, and have used my current wheels for three years with no problems (recent issues with nipples have to do with corrosion, caused by living near the sea, I would imagine).
Regarding the hubs, given your size, I would probably go with the DT 240 hubs. I've read that they are more robust, and have been using them on several wheelsets (Reynolds and Bontrager - road and mountain) without issues. They may be a little heavier than the 180's or 190's, but can take a beating.
Madone 9 http://weightweenies.starbike.com/forum/viewtopic.php?t=143973
Crockett http://weightweenies.starbike.com/forum/viewtopic.php?t=130567
Madone 5, Madone 4, SpeedConcept, Cobia
I own a lot of Treks.
PostPosted: Sat Oct 12, 2013 9:14 pm
Zen (roland) built my enves 3.4 alchemy ELF Cx rays weight was 650g . Rear with power tap g3 hub was 764g so 1414g with rim tape.. Considering the power tap hub .. I'm extremely pleased with weight.
PostPosted: Sun Oct 13, 2013 4:16 pm
The biggest concern manufacturers have with heavier riders and carbon clinchers is prolonged braking. You heavier guys better get your technique down. The better manufacturers have improved heat management by leaps and bounds, but no company can guaranty against a +225lb rider cooking the brake track on a long, steep descent by dragging the brakes. Leave the carbon clinchers home if you are headed to the mountains.
Honestly at your weight, I would choose a clincher that you can up the spoke count. The Enve Classic 45 and 65 can be had in 28 hole so you can get a set built up 24/28 instead of 20/24 like the Smart line. With the mixture of hills and flats I would go with the 65mm rims. in 24/28 they will be a very strong set of wheels.
www.ergottwheels.com
There are no new unread posts for this topic. Budget Carbon Clinchers
in Everything wheels
Ltoddokc
Tue Oct 18, 2016 10:12 am
Juanmoretime View the latest post
There are no new unread posts for this topic. SOLD ENVE SES 3.4 Carbon Clinchers
merlin3008
Sat Jan 21, 2017 6:45 pm
merlin3008 View the latest post
There are no new unread posts for this topic. Tubeless & carbon clinchers safety
twostroke
9
641
Mon Mar 27, 2017 8:28 am
Marin View the latest post
There are no new unread posts for this topic. Why is my ksyrium SL heavier than it should be?
zalle
Thu Nov 10, 2016 11:27 am
Lelandjt View the latest post
There are no new unread posts for this topic. Who is running latex tubes on carbon clinchers?
RJKflyer
41
2213
Mon Mar 27, 2017 5:57 pm
Multebear View the latest post
Users browsing this forum: hm123 and 7 guests
