It is currently Wed Jan 17, 2018 2:28 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Mon Sep 30, 2013 7:21 pm
I have a 2011(?) pair of Zipp 404 Carbon Clinchers that I haven't ridden much in the last year because my other wheels have a powertap. I figured I could grab one of the clearance priced Powertaps off chainlove and go ahead and build this thing up. So what I've got is:
Zipp 404 20h x58 rim
Zipp firecrest rim washers
Powertap G3 20h 11spd Shimano
DT Aero Comp spokes (wanted a stiffer wheel than CXRays or Aerolites would yield)
I am definitely doing 2x on the non drive side (required by the powertap) but I figured I have some options as far as drive side lacing goes. If I go 2x, it looks like it might be tough to get enough spoke tension on the NDS since spokecalc says it'll be a 46% tension ratio and Zipp recommends 100kgf for build tension. If I go 1x, it'll be slightly better tension balance, at 48%. If I went radial heads-in, it could potentially be a lot better, but then I'm depending on the G3 hub to transfer ALL the torque of the driveline.
I figure I could just build it up 2x (since I have that length spoke ready to go) and see if the NDS gets to an acceptable tension... Then re-do it 1x if I feel I really need to.
Would doubling-up on the DS rim washers allow me to use a higher tension?
PostPosted: Tue Oct 01, 2013 5:29 am
Doubling up can cause shifting. I would not do a radial lace with heads-in, because of the increase in approach angle of the spokes to the rim. I see a lot of broken spokes on 404 Powertap wheels..
PostPosted: Wed Oct 02, 2013 8:53 pm
Thought I would post this here since a web search didn't turn anything up for me.
I knew the Zipp rims have a recommended upper tension of 100kgf, however I the conversion table card that came with my Park TM-1 Tensiometer doesn't have an entry for the DT Aero Comp spokes.
These spokes are 1.2x2.3 (basically a thicker version of DT Aerolite, ideal for adding stiffness to a wheel with minimal drawbacks).
I rigged a spoke hanging from my bench vise and loaded it using a right-angle piece of thick metal with a thin slot and a big 'eye' loop so that I could rig weight from it. From the sling I hung a super heavy duty milk crate that I could easily stand from, then added enough free-weight plates to bring the total weight (including myself) up to 220lbs (100kgf). The whole assembly was about a half inch off the shop floor so if anything broke, minimal chance for injury.
As it turns out, 100kgf reads at 16.5 on my Park TM-1.
PostPosted: Wed Oct 02, 2013 9:18 pm
good job for calibration of TM1
i get new from parktool and it show much higher tension than actual
http://kavitec.blogspot.com/
My NEED FOR SPEED ride:)
https://www.youtube.com/watch?v=8hhlPRud7oM
PostPosted: Thu Oct 03, 2013 4:44 pm
You can do 1x heads-in on the DS, and use stiffer DS spokes (DT AeroComp from Fairwheel) to help keep the NDS spokes from losing tension.
formerly rruff...
PostPosted: Thu Oct 03, 2013 5:18 pm
I ended up doing Aero Comps, 2x, both sides. Should I have stuck with lighter stretchier Aerolites on the NDS?
I see for 2014, Zipp has even gone to 2x both sides, but with 24 spokes. I guess they were getting some feedback that the old 20spoke CXRay build just wasn't stiff enough.
PostPosted: Fri Oct 04, 2013 11:50 am
2X both sides and get the tension up to 120kgf. Zipp doesn't even listen to that 100kgf with their in house builds. I've measured 125-130kgf before I disassembled them. I've rebuilt several FC 404s to PTs and had no problem with higher tension.
Any rim that has washers and a 100kgf limit would be the biggest piece of crap ever.
www.ergottwheels.com
There are no new unread posts for this topic. Price drop Zipp 303 Tubular with G3 powertap built in. $1050 Usd
bazmac
Thu Nov 23, 2017 1:55 pm
bazmac View the latest post
There are no new unread posts for this topic. Rebuilding Sram HydroR calipers
MayhemSWE
Sun Jul 23, 2017 10:08 am
bikewithnoname View the latest post
There are no new unread posts for this topic. Rebuilding wheels with deep section rim
in Everything wheels
12element
Sat Jul 22, 2017 2:48 am
alcatraz View the latest post
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. Wanted: UK -100mm Enve, Zipp Sprint or Zipp Speed Stem
in Wanted
iamalex
Sat Jan 06, 2018 1:03 pm
iamalex View the latest post
Users browsing this forum: ku_hi and 4 guests
cron
