It is currently Tue Jan 16, 2018 8:54 pm
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: Chainging Rims & ERD
PostPosted: Thu Sep 26, 2013 12:44 pm
I'd like to change out my Kinlin 270 (ERD 587mm) to a wider rim. I'd like to keep the costs down, so if I can reuse my spokes, that's a plus. The ERD of a Pacenti SL23 is 588mm, which is much closer to the 270 than the Kinlin 279 @ 584mm.
Is it likely that I'll be able to reuse my spokes with the Pacenti?
FWIW: This is being used with an White Ind H3 hub and CX Rays.
 Post subject: Re: Chainging Rims & ERD
PostPosted: Thu Sep 26, 2013 1:28 pm
If Pacenti is only 1mm greater diameter, that's 0.5mm on the spoke length, which is immaterial. You will be fine. Use new nipples though.
There's sometimes a buggy.
One.
PostPosted: Thu Sep 26, 2013 1:38 pm
Great. Thanks!
PostPosted: Thu Sep 26, 2013 6:24 pm
Shouldn't be an issue at all. Like bikerjulio mentioned though it would definitely be a good idea to replace the nipples. Obviously you will want to make sure you stick with the same lacing, but also make sure that if you disassemble the wheel entirely that you relace the spokes in the same fashion as before (ie pull spokes in pull holes, lead spokes in lead holes etc) just so that the grooves in the spoke holes match up to the new wheel. That will ensure that the j bends will sit flush in the spoke holes.
http://www.zencyclery.com
There are no new unread posts for this topic. Anyone seen this on rims?
Bergwerk
Sun Jan 14, 2018 12:21 am
bm0p700f View the latest post
There are no new unread posts for this topic. Water in the rims......
in Everything wheels
TonyM
23
1302
Tue Nov 21, 2017 7:52 am
TonyM View the latest post
There are no new unread posts for this topic. Magnesium rims??
Phill P
9
844
Sat Jul 15, 2017 4:08 am
pdlpsher1 View the latest post
There are no new unread posts for this topic. XC Racing Rims?
in MTB
Lelandjt
44
5642
Mon Jun 05, 2017 9:40 am
Klaster1 View the latest post
There are no new unread posts for this topic. kg/f for Shamal 90's rims
pinkSanta
Wed Mar 08, 2017 11:02 pm
Users browsing this forum: No registered users and 5 guests
cron
