Alchemy Orc-UL is this wear normal?
asv
by asv
Check out the wear on this hub body, is that normal? I'm getting a lot noise on my dura ace 9000 cassette in the larger cogs and I'm not sure if it's just the cassette or a result of this wear.
kavitator
by kavitator
all aluminium freehub has that kind bite from sprocket (Tune, Dt swiss, Novatec, Bitex....)
Check if cassete is enough tightened
asv
by asv
Thanks!
bikerjulio
by bikerjulio
Suggest you check out the exploding DA cassette thread.......
There's sometimes a buggy.
One.
LouisN
by LouisN
The freehub body is pretty short (Shimano 10sp. version). You can't put the 10S DA cassette without using a spacer because the lockring can't be tightened hard enough...because of this you should see MY freehub body... :oops:
Louis :)
bikerjulio
by bikerjulio
LouisN wrote:The freehub body is pretty short (Shimano 10sp. version). You can't put the 10S DA cassette without using a spacer because the lockring can't be tightened hard enough...because of this you should see MY freehub body... :oops:
Louis :)
what are you talking about?
OP has an 11 speed cassette with noise coming from it. Are you not paying attention?
da-da-da-dum
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=118879
One.
LouisN
by LouisN
+1 what Kavitator wrote.
Of all the hubs I have (all alloy freehubs), the biggest "bites" are on my ORC-UL.
Very useful comment BTW Julio...
Louis :)
ergott
by ergott
Lockring torque spec.
I've seen that and worse from all alloy freehub bodies.
wojchiech
by wojchiech
American Classic sells cassette pins that prevent the loose cogs from biting into freehubs. You can go the DIY route and use staples from a staple gun. Steel freehubs of course don't have this problem, and neither do SRAM Red cassettes since there are no loose individual cogs.
Better to do something now though to prevent any further damage to the freehub. I've had cassettes bite so hard into Al freehubs that they got stuck.
Zen Cyclery
by Zen Cyclery
This is quite normal. I've seen some that are so bad that I could barely get them off even with a vice-whip and a lockring removal tool.
kavitator
by kavitator
CAmpagnolo freehub is bite proof :)
bikerjulio
by bikerjulio
LouisN wrote:+1 what Kavitator wrote.
Louis :)
If you weren't so busy being a smart alec :lol: you might have read this:
and wondered whether or not OP could possibly have the cassette problem I referenced, rather than posting some irrelevant comment about 10-speed and spacers :D
One.
LouisN
by LouisN
I must admit you are right in an absolute way Julio.
@asv: Sorry I mislead you. My post was irrelevant because I used my 10S experience to illustrate my thoughts. Do not check if you have proper cassette installation, leading to improper lockring torque.
Ah! And beware of those Shimano Dura Ace 9000 cassettes, I read they were responsible for nasty freehub bites, moments before exploding in pieces...
Louis :)
bikerjulio
by bikerjulio
LouisN wrote:I must admit you are right in an absolute way Julio.
Louis :)
watch the clip.
you only saw me one more time :)
One.
LouisN
by LouisN
BikerJ,
I'm not into fiction characters, really.
Fact is (to get back to topic) I gave my honest opinion to asv, and most of the other members seem to agree with me.
da-da-da-dum
That comment was uncivil, and irrelevant IMO. I really seriously don't get your point...
Louis :)
