It is currently Thu Jan 18, 2018 3:22 am
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 Next
 Post subject: TUNE carbon clinchers
PostPosted: Fri Aug 16, 2013 3:35 pm
I am wondering if anyone has any insight into tune's upcoming carbon clincher wheelsets (see links)? They look too good to be true....I am especially curious to know if their brake track is up to snuff with the firecrests, enve's, and cosmic carbone 40C. I know that there will be people who downplay carbon clinchers, but I haven't the patience to deal with gluing tires onto tubular rims, not do I want to deal with flats while out on the road.
http://fairwheelbikes.com/c/forums/topic/tune-2014-wheelsets-sneak-peek/
http://www.bikerumor.com/2013/07/31/tune-offers-sneak-peek-at-new-line-of-carbon-road-wheels/
PostPosted: Sat Aug 17, 2013 4:20 pm
Well, you knew they were working on something when they called out enve for having "heavy" carbon clinchers a year ago. I'm interested to see what these are all about as well.
PostPosted: Sun Aug 18, 2013 3:51 pm
It'll be interesting to see how they compare with the big boys. But I'm pretty sure there will be a weight limit and my 76 kgs will be too heavy for them anyways!
PostPosted: Sun Aug 18, 2013 3:59 pm
Per the linked http://fairwheelbikes.com/c/forums/topic/tune-2014-wheelsets-sneak-peek/, rider weight limit is 90 or 110 kg, depending on the model.
PostPosted: Sun Aug 18, 2013 5:56 pm
True - but that is the maximum weight limit. I wouldn't want to chance it. It's like the Fulcrum wheel FAQ says...
{USERNAME} wrote:
If you weigh over 109 kg/240 lbs we advise you not to use this product. Non compliance with this warning can damage the product irreversibly. If you weigh 82 kg/180 lbs or more, you must be especially vigilant and have your bicycle inspected more frequently (than someone weighing less than 82 kg/180 lbs).
In my mind, anything with a weight limit is best suited to people who don't ever have to worry about weight limits (i.e. in the 60-70 kg range).
PostPosted: Sun Aug 18, 2013 6:28 pm
Which makes Enve's weight without a limit even more impressive!
PostPosted: Sun Aug 18, 2013 11:59 pm
I don't believe Tune and Enve are targeting the same markets of customers. There may be some overlap, obviously, but Tune is targeting a much smaller market than Enve.
Enve and ZIPP design products that can end up on a full brand's OEM range. That means they need to have design specs for any possible type of person using their product in the intended method.
Tune has products for people who want to invest in the upgrade of their existing equipment or a custom build. That means they design their products for a particular range of person which they've found to be within their target market.
Different types of apples that we're comparing here.
PostPosted: Mon Aug 19, 2013 3:48 pm
I'll see if they have them at Eurobike next week and post pics.
carbonLORD.com
PostPosted: Thu Aug 22, 2013 3:02 am
Thanks. That would be great. Any info, especially about the braking would be appreciated.
PostPosted: Sun Aug 25, 2013 2:38 am
Also any info on when these might be released/available. They seem too good to be true.
PostPosted: Thu Aug 29, 2013 2:12 pm
.......so wondering if there is any other news about these wheels besides the following link which was posted in another thread?
http://www.rouesartisanales.com/article-53430311.html
my french ability to read french is zero, and google translate did not show that the page said anything useful.
PostPosted: Thu Aug 29, 2013 2:18 pm
They do seem a bit too good to be true. Not to wander too far OT, but are Tune rear hubs still using an alu cassette body? :?
My EPS: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=72682
PostPosted: Thu Aug 29, 2013 3:07 pm
When was this?
Any link handy please?
VeloKicks
The Gram
The Men of Steel
PostPosted: Thu Aug 29, 2013 3:10 pm
Pretty much everyone uses an aluminium freehub body for their lighter performance hubs. Shimano DA and White Ind use titanium. But their rear hubs are in the 250g range while Tune's hub set weighs under 200g.
PostPosted: Thu Aug 29, 2013 6:21 pm
Thanks. I have very bad memories of a DA 7800 cassette eating into my Tune rear hub within 50 miles.
There are no new unread posts for this topic. ENVE 3.4 SES Carbon Clinchers...like new!
merlin3008
Thu Nov 09, 2017 2:52 pm
merlin3008 View the latest post
There are no new unread posts for this topic. Tubeless & carbon clinchers safety
in Everything wheels
twostroke
9
1341
Mon Mar 27, 2017 8:28 am
Marin View the latest post
There are no new unread posts for this topic. Who is running latex tubes on carbon clinchers?
RJKflyer
41
3878
Mon Mar 27, 2017 5:57 pm
Multebear View the latest post
There are no new unread posts for this topic. Sub 1000€, 100% German made 1370g Carbon Clinchers
[ Go to page: 1 2 3 4 5 6 ]
leej88
87
19165
Sun Dec 10, 2017 2:42 pm
JayUK View the latest post
There are no new unread posts for this topic. Boyd Cycling 28mm carbon clinchers experiences?
btothec
Sat Jun 24, 2017 1:32 pm
btothec View the latest post
Users browsing this forum: No registered users and 6 guests
