It is currently Sat Jan 20, 2018 8:33 am
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Sun Aug 04, 2013 7:02 am
I just commented in the Flo 30 thread and it got me thinking - why do people choose the rim depth that select for thier Al clinchers?
Trade off between weight and stiffness? Aero vs weight? Appearance? Number of spokes you can use?
When I next build up a set of rims I'll be looking at the Pacenti's - decent moderate weight, stiff, and a little aero. Really want to try some wide rims (widest I've used is campy rims which I think were 21/22mm wide)
Most popular rim depths (in custom wheels) seems to be 24-28mm - but what is the motivation behind that? I'm hoping some of the wheel builders offer an insight.
Most of the big name prebuilt clincher wheels tend to target lighter lower profile rims (Shimano, Campy, Mavic)- but then they are targeting OEM sales and hence light weight sells on the show room.
PostPosted: Sun Aug 04, 2013 4:28 pm
Over 32mm or so, alu is almost always heavier than carbon. Under 24mm or so, rims tend not to be as stiff, so higher spoke counts (i.e. more weight) become necessary.
In the 24-32mm range you can build something that's fairly light, and/or fairly strong, and/or fairly cheap. (Pick 2.) You can even have a bit of aero, although the differences are relatively trivial for the most part.
Blog: http://thesetbackpost.com/
PostPosted: Sun Aug 04, 2013 4:32 pm
That's the depth range you need for good aero performance (along with a rounded shape) and depth also influences lateral stiffness quite a bit.
formerly rruff...
PostPosted: Sun Aug 04, 2013 4:33 pm
Not trivial... unless you think Zipp 808s are also trivial.
formerly rruff...
PostPosted: Sun Aug 04, 2013 4:50 pm
I said in "in the 24-32mm range". I meant the aero advantage of 24-32mm rims is relatively trivial compared to traditional low profile rims. Admittedly that may not apply to rims like the Flo or the Zipp 101 but for the most part you aren't going to see significant aero gains without going quite a bit deeper.
PostPosted: Sun Aug 04, 2013 5:47 pm
what about Kinlin xr380---higher but awsome rim. fast stiff nice looking
http://kavitec.blogspot.com/
My NEED FOR SPEED ride:)
https://www.youtube.com/watch?v=8hhlPRud7oM
PostPosted: Sun Aug 04, 2013 6:26 pm
It's not light though - 550g.
PostPosted: Sun Aug 04, 2013 7:25 pm
The XR380 is a pig of a rim. I think that in the real world the XC279 is far more versatile (and dare I say aero) rim, especially with the crosswinds.
http://www.zencyclery.com
PostPosted: Mon Aug 05, 2013 12:04 am
Not true at all. Have you looked at the data? Something like a Pacenti or XC279 would be closer to the 808 than a "traditional low profile rim". If you also use round spokes the difference is huge.
formerly rruff...
PostPosted: Mon Aug 05, 2013 12:58 am
Please provide references. The only data I have seen backs up the assertion that these rims aren't anywhere near the aero performance of a Zipp 404, not to mention an 808.
I have also only ever heard that rounded vs bladed spoke differences are minute. But I am most recently thinking of the wind tunnel testing that November did. AFAIR, that is why they decided to use round on their 30mm alloy wheels.
PostPosted: Mon Aug 05, 2013 1:19 am
The number of spokes has a much bigger effect on aerodynamics than the shape of the spokes IMHO. The XC279s feel 'aero', but this could be due to lower rolling resistance or comfort due to tire shape, or both.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Mon Aug 05, 2013 10:40 am
+1.
PostPosted: Sat Aug 10, 2013 5:22 am
Then please provide references for *your* data.
I said they were closer to an 808 than a shallow rim with lots of round spokes.
I have a large collection of wheel wind tunnel tests that prove the point. Not seeing that I can upload files here though. Tour has one of their QTRs online however, and you can see a good cross section of different wheels there. Note particularly:
Komponentix All-Weather, shallow rim, 28 round spokes 47.1W.
Corima Winium+, rounded 22.5Wx23.3D rim, 18 aero spokes, 27.2W
Zipp 808, 19.5W
This is typical.
http://www.tour-magazin.de/services/qtr ... page3.html
formerly rruff...
PostPosted: Sat Aug 10, 2013 11:16 am
SO what I'm trying to pick out of this.....
-A rim over 500grams is starting to be considered too heavy no matter what the profile.
-Either side of 450grams typically gives a good trade off of properties
-Nobody is ever going to agree that a sub 35mm rim is really "aero", just that it is a bit more aero than a set of 32 spoke open pros....
PostPosted: Sat Aug 10, 2013 2:53 pm
Even a 25mm rim can be quite aero, if it's wide and rounded. The place where the *good* deep rims see the biggest advantage is at high yaw... which is precisely where most riders start wishing they weren't on deep rims anymore!
If you are serious about TTs then deep rims make sense. If you are serious about road racing then carbon tubulars are the ultimate. But most riders buy deep carbon rims for style. Nothing wrong with that, but the speed gains (if any) over a good aluminum rim like the SL23 or XC279 are trivial.
formerly rruff...
There are no new unread posts for this topic. The common mistakes we do?
wheelsONfire
35
3870
Wed Feb 15, 2017 8:39 am
TheDarkInstall View the latest post
There are no new unread posts for this topic. Campag Bora One 35mm clincher weight
in Everything wheels
liam7020
20
2668
Tue Aug 08, 2017 11:59 pm
stockae92 View the latest post
There are no new unread posts for this topic. Enve Classic 45 Clincher weight limit
Alpine318is
11
1083
Tue Jan 31, 2017 7:24 pm
Alpine318is View the latest post
There are no new unread posts for this topic. Attachment(s) Which Wheelset is better with Shimano C60 Clincher vs bora one 50 clincher
oraclesin
13
1554
Wed Aug 09, 2017 8:35 pm
nemeseri View the latest post
There are no new unread posts for this topic. Focus Izalco Max eTap starting weight 6.62kg current weight 6.46kg
btothec
9
2399
Thu Jun 22, 2017 3:24 am
btothec View the latest post
Users browsing this forum: No registered users and 5 guests
cron
