It is currently Fri Jan 19, 2018 10:46 pm
Post new topic  Reply to topic  [ 2 posts ]
PostPosted: Wed Jul 31, 2013 4:12 am
Just picked up a BMC Alpenchallenge to commute with. it's HEAVY. (9.4kg)
Can someone recommend a good, light set of clinchers that can accommodate larger (i.e. cross size) tires and disc brake rotors?
PostPosted: Sat Aug 03, 2013 1:27 am
I have two sets of wheels for my commuter/cx bike: for normal commuting I have a set of H+ Son Archetype (23mm-wide) rims and for cx I have a set of Stans Crest wheels running tubeless with Kenda Kommando SCT tires.
Both wheels will accept wide tires, but if you want to run high-pressure road the Crest may not be appropriate (I am not sure if max pressure they list is only for tubeless). I really like how wide the Crest are for 32mm cross tires.
I built both sets laced 28/32 3x with DT SuperComp spokes to BHS hubs. (I weigh ~175 lbs for reference.) Using the same hubs means adjustment-free swapping. (I swap the wheels frequently since I ride an off-road commute route when the trails are dry.)
There are no new unread posts for this topic. Mavic cosmic pro carbon sl ust disc brake front wheel only brand new
gotgame
Sat Dec 09, 2017 11:28 pm
gotgame View the latest post
There are no new unread posts for this topic. New Specialized Disc wheel Roval 007 disc.
Slack
Thu Dec 14, 2017 4:16 pm
TurboKoo View the latest post
There are no new unread posts for this topic. Disc brake AND rim brake?
in Everything wheels
MiddMan
12
925
Sat Jul 15, 2017 2:52 pm
dmulligan View the latest post
There are no new unread posts for this topic. disc brake rotors
erickr
9
711
Wed Jan 10, 2018 12:07 am
reippuert View the latest post
There are no new unread posts for this topic. Reynolds disc wheel
Ahillock
Sun Oct 08, 2017 3:46 am
Ahillock View the latest post
Users browsing this forum: bremerradkurier and 1 guest
