It is currently Mon Aug 21, 2017 3:58 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
 Post subject: Re: Tubeless Road Rims
PostPosted: Thu Aug 22, 2013 5:12 pm
OK, so only one person answered the question. So then for everyone who recommends setting up non-tubeless-specific rims tubeless, do you have a list of rims that are known to work? FIJIGabe mentions 2, but again, I'm interested mainly in aftermarket rims, not complete wheels.
PostPosted: Thu Aug 22, 2013 5:39 pm
Almost any clincher rim will work. The ones to stay away from are non-annodized rim surfaces, but even that depends on what sealant you run. Personally, I wouldn't trust Mavic rims, or any of the Shimano rims that aren't listed as "tubeless", because they use raw aluminum, that is suceptible to corrosion. My friend ran a set of DA 7800 rims with Stans in them, and eventually, he couldn't get the tire to seal due to the corrosion inside the rim.
My recommendation is to find a light rim of your choice, and begin the setup process.
Madone 4, SpeedConcept, Cobia
I own a lot of Treks.
PostPosted: Thu Aug 22, 2013 7:52 pm
I've used the following clincher rims successfully with Stan's yellow tape and tubeless tires:
Kinlin XR19W
Kinlin 270
Enve SES 3.4 (25mm tape instead of 21mm tape)
Enve 65
Stans ZTR Alpha 340
Farsports 50cm (old version, not the wide version)
Some rims were harder to inflate and seat the tubeless tire. The Enve 65 were the toughest to inflate and seat. I ended up using CO2 to get the tubeless tires on the Enve 65.
2013 Colnago C59 TSMR
2012 Colnago C59 CSLM
PostPosted: Thu Aug 22, 2013 10:34 pm
For un-anodized rims, I use the "ghetto" approach, and it works well. I'm rolling on Aksiums on my commuter bike tubeless and some Alex random stuff on my CX bike with no problems. "Ghetto" is where you stretch an undersized tube around the rim and then slice off the excess. It creates a barrier so no sealant touches the rim.
PostPosted: Fri Aug 23, 2013 2:11 am
I tried Gorilla tape on MTB rims awhile back. I tried to pull it tight like the Stans stuff and it just snaps. Maybe getting it tight isn't so important, but given that it is also much heavier, I will just pay the $11 for Stans which I known works perfectly and doesn't have to be cut down to size.
+1 for running any rim tubeless. The H+ Son Archetype is a nice option given the anodized black sidewalls. Much cheaper than the SL23, but not much heavier. Also welded. Beautiful rims. I have had great luck with Kinlin rims tubeless too. I don't think road tubeless is all that great (didn't flat less and the ride on Hutchinson Fusions wasn't as good as a GP4000s), but i will say that road tubeless is much easier to setup than mtb. The only rims that have given me any trouble are full carbon rims which were very loose. I look forward to trying better tires in the future and changing my mind. I really wanted to be converted.
PostPosted: Tue Aug 27, 2013 6:37 pm
Thanks all for the specific suggestions.
pushstart - All Hutchy road tires ride like crap. Try a Bontrager R3 or R2 tubeless, Schwalbe Ultremo ZX tubeless, or Specialized Roubaix tubeless.
PostPosted: Tue Sep 10, 2013 12:43 am
Yeah, I suspect you are right. I will reserve final judgement on (road) tubeless value until I have a chance to try those. I have hears great things about the Bonty R3.
PostPosted: Wed Sep 11, 2013 5:52 pm
Agreed. I used to ride Hutchys and I never had any complaints. I didn't realize how harsh they were until I switched to Bonty tubeless. They seem to be a bit more supple than the Hutchys and hopefully they'll be as durable.
http://www.zencyclery.com
PostPosted: Wed Sep 11, 2013 6:12 pm
Good experiences with the Pacenti SL23 and Stan's Alpha 400. The right choice depends on you and your riding. I've killed a couple of Schwalbe Ultremo ZX tires this season. They feel fragile to me but the ride is nice.
PostPosted: Wed Sep 11, 2013 8:18 pm
Has anyone tried converting the H+Son Archetype to tubeless with CX tires?
PostPosted: Thu Sep 12, 2013 12:18 am
@gospastic- I've set the Archetypes up tubeless for road but not for cross. Which tires were you thinking of running? Also what tubeless interface were you thinking of?
PostPosted: Thu Sep 12, 2013 4:45 pm
I'm not really sure. It would be my first venture into the world of tubeless. Any recommendations?
PostPosted: Thu Sep 12, 2013 8:49 pm
I've heard good things about the MIchelin Mud 2 all though I have no direct experience with it. For the tubeless interface though I'd just go Gorilla Tape with Stans stems/valves.
PostPosted: Mon Sep 16, 2013 3:46 am
I have used the Archetypes tubeless (also road). I imagine they will be fine for cx, but I have found that those lower pressures tend to be more finicky about the tire-rim interface. I would stick with Stans tape personally unless you need to build it up for seating, but if you're running cx pressures, then sounds like 1 layer would be enough.
I have only ridden a few cross tires, but I am currently very happy with the Kenda Kommando SCT tires. Good weight and have survived a lot of singletrack riding without flatting yet (knock on wood). My cx wheelset is Stans Crest, though; I imagine the extra width helps. My buddy ran mud 2 tires and had many, many flats on the same trails. But that might just have been him.
I also recommend against the Hutchinson Piranhas.
PostPosted: Tue Oct 01, 2013 11:43 pm
Kinlin XR19W
Kinlin 270
Enve 65
Stans ZTR Alpha 340
Looking to pick us a set of Enve 3.4 and would like to set up tubeless I would like to here the results. What tires and valves are you using?
There are no new unread posts for this topic. lightweight tubeless rims
in Everything wheels
dtwolfen
23
1584
Tue May 30, 2017 2:28 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Mavic Road Tubeless
Geoff
24
1870
Wed Jul 26, 2017 10:09 am
TobinHatesYou View the latest post
There are no new unread posts for this topic. Attachment(s) Suppple Road Tubeless?
possibleweenie
Sun Aug 20, 2017 6:30 pm
possibleweenie View the latest post
There are no new unread posts for this topic. Road tubeless without sealant?
Garrison
15
981
Sun Jun 25, 2017 12:40 am
gewichtweenie View the latest post
There are no new unread posts for this topic. Share your Road tubeless setups
[ Go to page: 13 4 5 6 7 ]
prebsy
91
8996
Mon May 08, 2017 1:14 pm
prebsy View the latest post
Users browsing this forum: dualathlonpc and 5 guests
