It is currently Tue Jan 16, 2018 10:52 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed May 22, 2013 10:32 pm
I would like to see them run all the major brands over this this machine. For those of us those of us that are not experts, I would like to see how others compare? Could be that no others can do it... Or maybe they all can?
http://beyonddork.blogspot.com/2013/05/carbon-fiber-road-wheel-test.html
Custom Steel is the ONLY way to roll!
http://www.kelsonbikes.com/
http://www.bikewagon.com/
PostPosted: Thu May 23, 2013 1:08 pm
Too bad the side loads are not in a place that is going to happen in real life. Should have it at the point of contact on the roller. Not to say that this wheel is good or bad, but just another way useless marketing will sell stuff.
PostPosted: Fri May 24, 2013 1:56 pm
I have to agree... the sideload needs to be applied at the bottom to be relevant.
formerly rruff...
PostPosted: Sat May 25, 2013 2:28 am
Another way of doing it would be to lean the wheel to the side a bit, maybe 30degrees max (or whatever the max is that someone observes an calculates in real use while going straight-like in a sprint).
Thing is, in real life, the side loads tend to be cyclic (pun intended), so then you'd want the wheel's inclination to maybe start at zero, and swing to one side and then the other slowly. But all of a sudden, it's hard to get a clear picture of what's going on when the wheel finally DOES fail.
So many variables...
PostPosted: Tue Jun 04, 2013 10:25 pm
dumbest test ever...
when on earth do you ever ride 50 mph over inch high nubs while a side roller is applied 90 degrees from the contact point of the ground...
PostPosted: Wed Jun 05, 2013 1:14 am
This test is closer/better, especially as the testing is being done with the tyre and tube fitted.
Not certain how well it is mimicking Torque effects and it still doesn't flip flop exactly like a sprinter/climber but closer ... nice machine :)
http://youtu.be/c7RJpf_KQo4
thanks KL :)
There are no new unread posts for this topic. Leather top vs. Carbon Fiber saddles (SMP Forma vs. Carbon Lite)
dgeesaman
Thu Aug 31, 2017 11:52 am
kgt View the latest post
There are no new unread posts for this topic. Help me please-Carbon fiber
Bianchi10
10
1545
Tue Jun 27, 2017 10:46 pm
thumper88 View the latest post
There are no new unread posts for this topic. Attachment(s) DIY Carbon fiber repair - seatstay.
BikeAnon
40
5658
Thu Nov 02, 2017 1:45 pm
BikeAnon View the latest post
There are no new unread posts for this topic. Carbon Fiber shifter clamps for Sram
nvroadie
9
1328
Fri Jan 20, 2017 4:04 am
Mep View the latest post
There are no new unread posts for this topic. Carbon fiber spokes + Alloy Rim = DISASTER(for MAVIC users)
[ Go to page: 1 2 3 4 5 6 ]
ohhyeok90
80
5492
Thu Nov 16, 2017 9:57 pm
antonioiglesius View the latest post
Users browsing this forum: No registered users and 3 guests
cron
