It is currently Wed May 24, 2017 12:33 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
 Post subject: The wide rim craze.
PostPosted: Sat May 11, 2013 11:22 am
Administrator
There are time when in the bike industry new and improved tend to be more marketing then actual benefit. I had this feeling when looking at the new bunch of wide rims coming out. Okay maybe they are not that new. I was wrong.
I've been doing a lot of fixed gear training and as it evolves wanted to ramp it up. My rear wheel was a Handspun which was not light but had excellent bearing and spun very well and smooth but the hub was fixed/free and I needed to put a track cog on the other side if I wanted to start using my fixed gear bike for team rides and not wanting to get dropped on the way back in. I looked at a bunch of pre-built wheels and everything was way to heavy and for the money I decided to have a wheel built.
Here was my build:
An All City 32 hole 120mm fixed/fixed black bolt on hub, black DT Revolution spokes, H Son Plus Archtype rim with DT black alloy nipples. It came in at 890 grams 200 grams lighter than my Handspun wheel and at least 300 grams lighter that the pre-builts in the same price range. FWIW, All City are excellent track hubs and its the same hub my Handspun wheel has.
Well, the new tire went on pretty easy compared to using the same tires hat I use on narrow rims and there was not much playing with the tube to make sure it was not under the tire. So far so good. Also I really did not read about the claims of a wide rim until after the first time I rode it to either figure out I was nuts or to reconfirm my ride perceptions. So the tire did go on easier than a narrow rim validating that claim.
On to the ride:
As I rolled down my driveway several pings as the spokes settled in as any new build will do. I noticed a difference in the ride right away. I felt like I had so much more grip on the pavement. The wheel itself felt more responsive and stiff, it is laced 3 across. I just felt like more of the pedal stroke was resulting into moving the bike faster. cornering was much more solid and confidence inspiring.
So I guess I'm sold. Has anyone else experienced this too?
:noidea: Now what to do about the front? :?
RESIDENT GRUMPY OLD MAN.
 Post subject: Re: The wide rim craze.
PostPosted: Sat May 11, 2013 3:57 pm
No wheel should ping upon the first ride. This should be taken care of by proper stress relieving in the truing stand.
Glad you like the new build though! The Archetype has the best braking I've seen on an alloy hoop.
http://www.WheelBuilder.Org
PostPosted: Sat May 11, 2013 4:16 pm
I dont really understand why the archetype rim is popular? Its a average weight alloy semi shallow rim ?
PostPosted: Sat May 11, 2013 8:36 pm
Is 23mm wide rim with a 19mm internal width.....that's why it is popular.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sun May 12, 2013 3:18 am
It is a really nice rim in terms of build quality too. I like the black braking surface since I am using archetypes for my disc commuter wheelset. That said, I think there were probably other factors at play if the ride felt significantly different. I think there is some detectable benefit in cornering, but most of this is probably just in your head :). Doesn't really matter, though, if it makes you happy to ride.
PostPosted: Tue Jun 04, 2013 10:38 pm
I've got a set of DT swiss 350 hubs on a HED belgium C2 rims (w/o brake track) inbound for a road disc bike. I'm hoping I have the same feelings you do about being glued to the pavement and cornering better.
If you don't mind me asking, what tires are you running?
PostPosted: Tue Jun 11, 2013 6:27 pm
I've used Archetype and A23. I cannot say I feel much difference cornering but defintely think they are more comfortable due to the lower pressure you can run.
PostPosted: Fri Nov 15, 2013 7:34 am
mjduct: Are you riding the C2's yet? I'm almost certain that my next project will be a disc road bike and would like to eliminate the brake track and any associated weight if I'm not going to be using it... Would love to hear your feedback. I'm hoping that the new Ardennes tubeless rims will become available soon as I'd really like to run 23mm tubeless on some nice wide rims.
PostPosted: Fri Nov 15, 2013 3:18 pm
I have c-2's with ck r45's, they have become my go to wheelset. The main difference is the ride, it is just smoother than any of my other wheelsets.
DAC24
FS 38mm actually smoother on the chipseal, however not ridden in the winter
Ksyrium Elite steel spokes
Ksyrium SLS
Fulcrum R-1
Rolf
Bontrager Supersomething
I know that the above wheels are narrower, however the wider ones really work great. Decending 35-50 mph and the century rides are where I feel the most benefits.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2013 Cannondale EVO Hi mod DA 9000
2015 Cervelo R5 DA 9000 No rotor.
2016 Specialized SWorks Tarmac Sram Red
PostPosted: Fri Nov 15, 2013 4:19 pm
I have a set of Kinlin XC-279 laced to DT 350s with 28/28 Sapim Laser spokes (Fairwheel Bikes built)......heavy at around 1700grams :gasp:, but I pull them off the shelf more often than my 1300 gram wheelset (XR-19w narrow rim), because they ride so damn smooth, and seemingly faster!
EDIT: Updated for my fat-fingering
Mosaic RS-1
PostPosted: Fri Nov 15, 2013 7:30 pm
Do you mean xc-279 or xr-270?
The 270 is a normal wide rim: 19mm outer width.
The 279 is wider: 23mm outer width.
PostPosted: Fri Nov 15, 2013 8:34 pm
I think that the Archetype is a great rim. The finish is far more consistent and quality than the A23, and if you don't mind the brake track finish wearing off then it's a great option.
With that said I think it's been out done by the SL23 from Pacenti. The SL23 is wider, deeper, and lighter while still being just as rigid.
http://www.zencyclery.com
PostPosted: Fri Nov 15, 2013 11:07 pm
I'm wondering how the Stan rims compare to these. People seems to agree on SL23 being the nicest rim compared to the A23 and the Archetype.
PostPosted: Fri Nov 15, 2013 11:30 pm
Last time I checked Stan's wasn't making a wide rim to compare with.
PostPosted: Fri Nov 15, 2013 11:41 pm
The Stan's Alpha rim is competitively wide (internally), but there is less material at the brake track. If you ride in adverse conditions, you might want to consider other options.
Sent from my DROID RAZR HD using Tapatalk 2
www.ergottwheels.com
There are no new unread posts for this topic. Can a Saddle Be Too Wide?
Valbrona
Mon Feb 27, 2017 8:36 pm
gtinut View the latest post
There are no new unread posts for this topic. Is 168 romin saddle too wide for me?
zalle
Mon Jan 23, 2017 5:09 am
mpulsiv View the latest post
There are no new unread posts for this topic. Wide alu (beachrace) disc rims
in MTB
Ghastly
Sat Oct 22, 2016 1:29 am
Getter View the latest post
There are no new unread posts for this topic. Old SuperSix, 23mm wide rims?
toshi
7
977
Mon Mar 27, 2017 5:07 pm
toshi View the latest post
There are no new unread posts for this topic. Recommendation needed for shoes with a wide toe box
in MTB
Champ5000
30
1771
Tue May 23, 2017 5:05 pm
LeDuke View the latest post
Users browsing this forum: CrankAddictsRich, WinterRider and 4 guests
