It is currently Sun Jan 21, 2018 1:55 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri May 10, 2013 11:29 am
Started gluing my own tubulars this year and riding them every day. Could kick myself for 20 years of clinchers - used to have the shop do the gluing and only ride them on race day. I have 404s with Vittoria Corsas - followed both mfrs instructions for gluing (three layers on rim, one on tire) - and got a very nice installation. Time to replace rear tire is approaching. I know I don't have to clean the rim down to new this time around, but how many tire changes/layers of glue do folks recommend before doing this ? Thanks.
PostPosted: Sat May 11, 2013 2:18 pm
Keep adding layers. If you remove a tire and the glue on the rim is chunky and irregular in height, then it's time to clean it off.
In general, more layers of glue is lower in rolling resistance (up to a point, I'm sure).
PostPosted: Sat May 11, 2013 8:31 pm
Doubt there is a set number of changes for replacing the glue layer. Probably total thickness is a better measure. If the dry glue is 1/4" thick, then its time to start over and clean the rim. If the glue is 1/8" thick, then add another layer. As already mentioned, if the glue is lumpy, comes off irregular and leaves spots of thick glue and spots of no glue on the rim, then probably start over. Having a consistent thickness of glue is important for rolling smooth. When I glued tubulars I put two coats on the rim and let them dry. One coat on the tire and let it dry. Then when actually mounting the tire I put a fresh coat on the rim and stretched the tire onto the rim. Held just fine. Used Continental tubular glue.
PostPosted: Tue May 14, 2013 6:17 pm
I would tend to agree with thisisatest.
PostPosted: Tue May 14, 2013 9:46 pm
This. Knock off the big chunks and keep gluing.
Glue sticks better to glue than to AL (or carbon)
M
PostPosted: Wed May 29, 2013 3:35 pm
So I'd been 'borrowing' a Grifo from a buddy who'd wrecked his Zipps, right?
He bought himself a new pair of Major Toms and needed a spare. So I pulled the tire off the rim and there were huge chunks of glue left on the rim.
I have this wire brush attached to the drill press in the garage. Used that to knock the big stuff off and smooth out some of the rest and then put another thin layer of glue on and really worked it to knock the high spots off. Before y'all get all wigged out, the glue gets into the bristles of the brush and all I'm really using to get glue off is more glue.
Seems to work for me anyway. No chemicals. Not much mess. You DO have to be careful tho.
M
There are no new unread posts for this topic. Yet another tube glue removal thread. (promise I read a lot of articles / threads)
in Everything wheels
gurk700
10
1080
Fri Feb 24, 2017 3:31 pm
victorduraace View the latest post
There are no new unread posts for this topic. 3M 08001 Glue
rgamble
Wed Apr 12, 2017 1:53 pm
rgamble View the latest post
There are no new unread posts for this topic. Arione 00 - which glue to hold covering down?
ParisCarbon
Sat Aug 05, 2017 2:55 pm
billspreston View the latest post
There are no new unread posts for this topic. Carbon Fibre repair glue to patch a seatpost?
Shrike
15
1778
Mon May 08, 2017 9:14 pm
thumper88 View the latest post
There are no new unread posts for this topic. Glue recommendations for Dura Ace Brake Lever Body
melchionda
Sun Mar 19, 2017 7:40 pm
motorapido View the latest post
Users browsing this forum: No registered users and 6 guests
cron
