It is currently Wed Mar 29, 2017 6:42 am
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: Rebuild or Replace
PostPosted: Mon May 06, 2013 8:34 pm
I've currently got a set of Reynolds DV3K's (2011), that I generally like a lot. I've been riding them for the last two years, and they have served me well, however, I'm getting the itch to try something new. As I'll be going 11-speed with my next bike purchase (probably Ultegra 6800 Di2, but possibly Red 22), these wheels can't carry over as-is. That begs the question: should I rebuild the wheels with new spokes and upgrade the hubs (currently proprietary Reynolds 10-speed hubs) to something that is 11-speed compatible, or just buy a new set of wheels?
Here are a couple of things to keep in mind: size-wise, I am not a weight weenie. I'm 6'4 and currently weighing 235lbs (down from 295lbs). The current wheels are clinchers, and I'm not interested in moving to tubulars. I'll upgrade both the front and rear wheels, in order to maintain matching appearance.
Suggestions welcome!
Madone 9 http://weightweenies.starbike.com/forum/viewtopic.php?t=143973
Crockett http://weightweenies.starbike.com/forum/viewtopic.php?t=130567
Madone 5, Madone 4, SpeedConcept, Cobia
I own a lot of Treks.
 Post subject: Re: Rebuild or Replace
PostPosted: Thu May 09, 2013 7:09 pm
Can't say for certain but most likely the hubs are *not* proprietary, but are made by one of the Taiwanese hub companies. In which case you'd have to find out which one and see if you can get an 11spd kit.
Or you might even be able to use a Wheels Manufacturing Accelerator 11 cassette on your current hub as is. The Campy 11 spacing is nearly identical to S11. Plus, WM might produce one that is specifically made for S11.
formerly rruff...
PostPosted: Fri May 10, 2013 8:58 pm
I think the generic hubs on recent Reynolds wheels are KT. If they are Novatecs you can get parts here: http://www.bdopcycling.com/Hubs-Road.asp
Have you tried asking Reynolds?
PostPosted: Wed May 15, 2013 4:09 pm
sorry for the delay in responding, i was having problems with the cookies issue on IE.
I saw that Reynolds did release an 11-speed freehub that appears to work on these hubs. I'm going to call them to confirm that. I may actually send the wheels back to them for RAP coverage, because they've developed a noise in the rim that sounds like pebbles rolling around in there. I stripped the wheels down (removed tires, rim strips, etc) trying to see if whatever it is will come out, but no luck.
There are no new unread posts for this topic. Wheel rebuild
in Everything wheels
GT8
13
586
Thu Dec 29, 2016 5:17 am
sugarkane View the latest post
There are no new unread posts for this topic. Trek Emonda ALR - Rebuild
Christono
Tue Mar 14, 2017 4:19 pm
gsindela View the latest post
There are no new unread posts for this topic. Rebuild XX1 der. to match XTR shifter
in MTB
Esben
Thu Mar 02, 2017 9:25 pm
HaakonJohansen View the latest post
There are no new unread posts for this topic. Upgrade or replace advice
apex
7
568
Fri Sep 09, 2016 7:29 am
GMF View the latest post
There are no new unread posts for this topic. Attachment(s) Specialized Tarmac Di2 What to replace?
sythe
19
2048
Thu Aug 18, 2016 10:46 am
rlarldhks86 View the latest post
Users browsing this forum: No registered users and 4 guests
