It is currently Sun Jan 21, 2018 2:23 am
Post new topic  Reply to topic  [ 22 posts ]  Go to page Previous 1 2
PostPosted: Wed Jul 03, 2013 9:22 am
Hello!
Where did you buy this sidecups?
Thanks
PostPosted: Wed Jul 03, 2013 9:11 pm
Look for 'sidecaps' on this page:
http://bdopcycling.com/Wheels-Parts.asp#SIDECAPS
PostPosted: Sun Aug 04, 2013 9:12 am
Just for the record I ended up using a non-driveside endcap on the driveside. It doesn't have the flange and allowed the lock ring to be tightened without compressing the bearing. I left a washer out to get the OLD near enough correct. Wheel has been usable and reliable.
Not the ideal solution perhaps but it works.
PostPosted: Sun Aug 04, 2013 12:20 pm
Recently built up a wheelset with parts from BHS.
Rear hub was their SL210 with Campy freehub.
Different problem.
In my case it was the lockring jamming onto rear dropout.
When comparing Campy 10 and 11-spd lockrings I notice that the 11 is 1.6mm thicker.
Put on a 10 spd lockring - problem solved.
There's sometimes a buggy.
One.
PostPosted: Wed Apr 02, 2014 9:36 pm
PowerMeister
Hi,
Does the campa body moves easily onto the axle? I have a F482SB novatec hub (originally with a 10 speed shimano hub) replaced it with a campa kit (same end caps as shown previously. I had to switch the washer from the non drive side to the drive side.. The shimano body came off easily but the campa body needed some force putting onto the axle... tighten the end caps resulting in the wheel not running as smoothly as with the shim body.. mounting the wheel resulted in a frozen wheel... it only happens when tighten the lockring... still searching for an answer...
"Racing is life. Anything before or after is just waiting."
--Steve McQueen--
PostPosted: Mon Apr 07, 2014 12:15 pm
Re Monza36, you need to file the flange off the driveside end cap. The lockring bears down on the flange otherwise and locks the bearings. More info in this post below, look at the 5th photo.
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=119840&hilit=campag+trp+hy%2Fdr&start=0
PostPosted: Sun Apr 20, 2014 3:18 pm
I'm getting ready to do this myself. Converting Shimano F482SB-11 to Campy 11-speed. Ordering the freehub from BDop. Can anyone else testify the process shown in this video is good enough, even though it says it applies to S482SB-SL?
https://www.youtube.com/watch?v=NNUpXfwjaWI
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
There are no new unread posts for this topic. Attachment(s) Need help - Is this cassette body from Novatec F482 rear hub?
itspat
Thu Nov 23, 2017 9:54 am
alistaird View the latest post
There are no new unread posts for this topic. Campagnolo Chorus HO Rear Derailleur
stormur
Mon Aug 07, 2017 11:30 pm
ultimobici View the latest post
There are no new unread posts for this topic. WTB: Campagnolo Bora One 35 Rear Clincher
in Wanted
deano87
Mon Nov 13, 2017 11:21 pm
deano87 View the latest post
There are no new unread posts for this topic. Campagnolo Bora Ultra 80 Rear
in Everything wheels
nismosr
7
471
Thu Nov 16, 2017 2:20 pm
nismosr View the latest post
There are no new unread posts for this topic. Campagnolo EPS Super Record rear derailleur
rosuch
Mon Oct 30, 2017 10:21 pm
avispa View the latest post
Users browsing this forum: No registered users and 6 guests
cron
