It is currently Sun Jan 21, 2018 12:14 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Mon Apr 29, 2013 1:37 pm
Planet X 50mm tubular rim.
Want Zipp valve extenders.
33 or 48mm ?
PostPosted: Mon Apr 29, 2013 2:05 pm
33
PostPosted: Mon Apr 29, 2013 4:36 pm
thx
PostPosted: Mon Apr 29, 2013 5:45 pm
surely it depends on the length of valve on your tub and whether it has a removable core?
PostPosted: Tue Apr 30, 2013 9:39 am
I won't be buying tubulars that don't have removal cores. I assumed valve length is standardised ?
PostPosted: Tue Apr 30, 2013 9:52 am
The zipp valve extenders fit over the top of existing valve and you have to leave the valve where it is, therefore you cannot close it unless you use topeak valve extenders with the inner valve closing tube. Most people with tubs on deep section wheels use removable valve core tubs and non-zipp extenders where you unscrew valve core from tub, fit valve extender with ptfe tape to ensure a permanent seal then refit valve core to the end of the extender, again with ptfe tape. This is a better solution.
PostPosted: Tue Apr 30, 2013 10:26 am
Standard valve length is between 38 and 42mm
PostPosted: Tue Apr 30, 2013 11:47 am
So use these ?
http://www.zipp.com/accessories/detail.php?ID=16687
PostPosted: Tue Apr 30, 2013 12:27 pm
Will you be using vittoria tubs?
Official cafe stop tester
PostPosted: Tue Apr 30, 2013 10:17 pm
Probably
PostPosted: Wed May 01, 2013 8:43 am
(Some) Vittorias have no real valves, but the really long red cores. Those only work with extenders for removable cores.
PostPosted: Wed May 01, 2013 10:40 am
I bought some Token extenders that are for removable core valves
PostPosted: Sat May 04, 2013 7:07 pm
OK so looks like the Tokens were a fail but at least it was a cheap fail
PostPosted: Sat May 04, 2013 7:36 pm
How are they a fail?
PostPosted: Sun May 05, 2013 11:50 am
Because the Vittorias don't have a removable core. They have a removable entire valve
There are no new unread posts for this topic. Grifo valve extension advice
alanmclean
Thu Oct 05, 2017 7:30 pm
alanmclean View the latest post
There are no new unread posts for this topic. Sealant and Valve Core Extension on High-Profile Wheels
Lightweenie
Fri Apr 21, 2017 11:52 pm
beatle View the latest post
There are no new unread posts for this topic. Quick question: Are Deda 31.7mm bars OK with non Deda stems?
hannawald
Fri Oct 20, 2017 10:41 pm
hannawald View the latest post
There are no new unread posts for this topic. Canyon H36 with Syncros Tri extension
dorin
12
1461
Fri Oct 20, 2017 1:52 pm
dorin View the latest post
There are no new unread posts for this topic. Valve extender help
4ibanez
7
552
Sat Jul 01, 2017 6:29 pm
4ibanez View the latest post
Users browsing this forum: No registered users and 3 guests
cron
