It is currently Fri Jun 23, 2017 1:31 am
PostPosted: Sun Apr 14, 2013 5:52 pm
Thinking about building a set of carbon tubbies, probably 38 or 50mm. I just acquired a set of the sweet silver Cmapagnolo Record hubs, and while I like 32 spokes on box section tubulars (and have a set of Nemesis on Campagnolo Chorus), I'm wondering if it's overkill and would be too harsh on a set of carbon rims. But if I used the Records I wouldn't need to buy another set of hubs.
Would you consider a set of 32f/r carbons? If so, when wouldyou consider them to be appropriate?
PostPosted: Sun Apr 14, 2013 7:15 pm
Online
Do they even make 32h carbon rims?
My Bikes
My Photoblog
PostPosted: Sun Apr 14, 2013 7:39 pm
I think you'de be hard pressed to find a 32 hole carbon hoop.
IMO that is overkill. I'm 100kg and I've ridden 20/24 carbon hoops no problem.
http://www.zencyclery.com
PostPosted: Mon Apr 15, 2013 12:08 am
Some Chinese manufacturers offer 32h options on their carbon rims.
I'd go 16h front radial / 24h triplet rear 2X:1X :smartass:
problem solved.
Louis :)
PostPosted: Mon Apr 15, 2013 5:21 am
Hi teleguy57, I don't know how heavy you are but the rear build could be ... a 32H campag hub and 24H rim for a 16-8 3xDS, 0x/1xNDS lacing for a super light tubular build :)
Just noticed LouisN's post ... what LouisN suggested but 3xDS and 0x/1xNDS :)
thanks KL :)
PostPosted: Mon Apr 15, 2013 11:29 am
Tubbie Guru
Hi,
Problem is that these Record hubs do not support radial lacing. At least, Campa strongly advises against it.
Ciao, ;)
PostPosted: Mon Apr 15, 2013 12:57 pm
That's what I thought last night after my post.... :oops:
1 X elbows out then for front....?
Louis :)
PostPosted: Mon Apr 15, 2013 2:29 pm
I would consider a 32/32 build with the low profile carbon rims, but I have no personal experience with them. I don't see it being a horrible idea if you get a set from one of the more reliable sources people talk about.
If you are looking for a nice way to build those rims up (tubular), get some Velocity Escapes. It's a pretty light alloy rim and it's proven to be a good rim.
I did these a LONG time ago. Wouldn't repeat. They certainly were strong. Story was, I had the rims built up to CHris King ISO hubs for a disc brake cross bike (remember the Cannondale?). Sold the bike and had the wheels. Decided to just relace the rims for road use and sell the King hubs.
www.ergottwheels.com
PostPosted: Mon Apr 15, 2013 7:13 pm
Eric, why is it you wouldn't build up the Zipps again? Too harsh?
What about Hed C2 tubulars 32/32? I'm shying away from them having seen a post referring to that build as "wagon wheels."
Hadn't really thought about low profile carbons. Would the primary difference between that a something like the Montreals or Escapes be weight (and cost)?
I'm probably over-thinking this anyhow:)
PostPosted: Mon Apr 15, 2013 11:10 pm
They were a bike harsh. That and you can't get 32 spoke Zipp rims like that anymore anyway. That was around 2004 or so.
For the road, I think Escapes will ride nicer than the Heds will. I haven't looked into the Chinese carbon rims for good or bad. I have other projects right now.
There are no new unread posts for this topic. FS: Nearly new Mavic Ksyrium Pro Carbon SL tubulars
RichTheRoadie
Sun May 14, 2017 10:53 am
RichTheRoadie View the latest post
There are no new unread posts for this topic. Carbon Climbing Tubulars under 1500$?
in Everything wheels
Pan
Thu Jun 01, 2017 3:21 pm
shineplus View the latest post
There are no new unread posts for this topic. Another carbon tubulars all round wheelset dilemma
nonamed
Thu Sep 29, 2016 11:30 am
nonamed View the latest post
There are no new unread posts for this topic. FS: Mavic Ksyrium Pro Carbon SL tubulars - Shimano/SRAM 11spd
RichTheRoadie
Sat Apr 29, 2017 12:55 pm
There are no new unread posts for this topic. Cervelo R3 - 1st carbon build
MandM
Tue Nov 22, 2016 2:55 pm
Klaster1 View the latest post
Users browsing this forum: justaute and 7 guests
