It is currently Sun Jan 21, 2018 10:11 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Thu Apr 11, 2013 3:02 pm
I was doing a bit of research for a university project and came across this
(pitch-based is the dialead)
Modulus is higher but strength is lower.
It seems if carbon rims were made of pitch-base fibres rather than PAN-based the heat issue would be solved.
Any thoughts?
--Max.
PostPosted: Thu Apr 11, 2013 5:03 pm
Good find!
Pitch based carbon fiber is already used in the Cervelo RCa, specifically in the downtube to stiffen up the bb, it is also used in our own A2J ROLO bike at various locations;).
Price is astronomic though..
rolobikes
PostPosted: Thu Apr 11, 2013 5:49 pm
those are impressive numbers!
that is going to be a REALLY STIFF rim though! ( may be good, may be bad. how much spoke tension would you need to true that wheel if i ever went out of true?)
maybe consider mixing the fibers- pitch based for the brake track only ( to keep costs down). sort of what they do with alu aero fairing wheels now
maybe some clever composite engineers like andy from a2J can tell us if that is possible.
PostPosted: Thu Apr 11, 2013 6:23 pm
For the record, I'm not a composites engineer; our tech boss Jon Gunner is though. He's the one that tells me these things.
rolobikes
PostPosted: Fri Apr 12, 2013 3:22 pm
Boy, it would be interesting. Pitch fibers, or at least the stuff I've messed with, is super brittle. Regular carbon, before the resin cures, you can tie in a knot. Pitch fibers are like uncooked spaghetti. Just goes snap.
PostPosted: Mon Apr 15, 2013 11:46 am
that would agree with the relatively lower yield strength adn high tensile modulus.
There are no new unread posts for this topic. Convince me on carbon fibre rims
in MTB
whyamihere
26
3587
Sat Jan 13, 2018 3:23 am
joshpeck View the latest post
There are no new unread posts for this topic. Designing and Building my own Carbon Fibre frame
euph
21
2913
Thu Nov 30, 2017 12:22 pm
euph View the latest post
There are no new unread posts for this topic. Carbon Fibre repair glue to patch a seatpost?
Shrike
15
1777
Mon May 08, 2017 9:14 pm
thumper88 View the latest post
There are no new unread posts for this topic. Mass Production of Carbon Fibre Solved by CSIRO and Deakin. Costs Set to Crash
mariovalentim
9
1981
Thu Feb 23, 2017 2:13 am
newforker View the latest post
There are no new unread posts for this topic. Tubeless & carbon clinchers safety
in Everything wheels
twostroke
9
1349
Mon Mar 27, 2017 8:28 am
Marin View the latest post
Users browsing this forum: No registered users and 4 guests
cron
