Post new topic Reply to topic  [ 4 posts ]
PostPosted: Wed Mar 20, 2013 2:34 am
Hi all,
I've got some Enve valve extenders that i'm trying to put on some Vittoria Corsa Evo tubs but they don't seem to match up.
Anyone else have this problem?
It looks like the valve extenders are expecting the tubs to be female but because the Evo's have a removable stem they are male.
Also, does anyone use a black permanent maker the base tape prior to gluing the tub to get rid of the tan color?
thanks all
2012 Scott Foil Premium
PostPosted: Wed Mar 20, 2013 12:29 pm
you need to use vittoria's red extenders
for instance like these...
http://www.probikekit.com/uk/tyres-tube ... -80mm.html
PostPosted: Sat Mar 23, 2013 4:17 am
I found these.
http://www.ebay.com.au/itm/Maxxis-MVS-6 ... 1268wt_908
they're better than the Vittoria ones because they have a removable valve core. This means you can remove the valve core and inject sealant.
Wasn't easy to find a valve extender that's a female fitting on both ends.
PostPosted: Sat Mar 23, 2013 3:40 pm
Get the Maxxis as mentioned above. Cheaper, they work fine, and they have removable cores.
http://www.treefortbikes.com/product/33 ... 1908___696
They show discontinued on that link, but you can get them still.
I run Vittoria Corsa CX on my Zipp 303 FC tubs, and run the 44mm version, they stick out just enough so you can pump it up fine, but don't have this ridiculously long stem hanging out.
I would think the 60mm+ for 404Fc or 80mms would work fine also.
Users browsing this forum: spytech and 6 guests
There are no new unread posts for this topic. Vittoria Corsa Evo CX tubies with removable valve core?
Gearhead65
9
910
Mon Jun 18, 2012 10:22 pm
fdegrove View the latest post
There are no new unread posts for this topic. Vittoria Open Corsa EVO Slick or Veloflex Corsa 22
btompkins0112
Fri Apr 19, 2013 6:08 am
markyboy View the latest post
There are no new unread posts for this topic. Difference between Vittoria Corsa CX III and Corsa Evo CX
mgordon
15
1848
Mon Apr 29, 2013 11:27 pm
There are no new unread posts for this topic. Vittoria Pitstop with Zipp extenders
12x23
11
1271
Wed Oct 10, 2012 9:59 pm
MDiddy View the latest post
There are no new unread posts for this topic. Vittoria Corsa Evo SC opinions
wassertreter
Fri Jul 06, 2012 11:18 am
It is currently Mon May 20, 2013 7:33 am
