Post new topic Reply to topic  [ 29 posts ]
Go to page Previous  1, 2
PostPosted: Tue Mar 19, 2013 5:33 am
@zen
when I said bladed I meant the flatter one or the other one the DB -double butted which comes either as 2-1.5-2 or 1.8-1.5-1.8
PostPosted: Wed Mar 20, 2013 1:28 am
Online
I'd go for 24/28.
If you are going to use DB spokes then go 2-1.5-2 on the front and 2-1.8-2 on the rear.
PostPosted: Wed Mar 20, 2013 10:32 am
DJT21 wrote:
I'd go for 24/28.
But preferably the 2.-0.9-2.3-2 front and rear or not? And yes eventually I have decided to go for the 24/28 since most of the responds were to go this way. What will be the recommendation for the lacing pattern??
PostPosted: Wed Mar 20, 2013 10:45 am
From http://www.superlight-bikeparts.com" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
recommendation for
rider weight Tune/Alpha 340
- 20/24 spokes to 75 KG
- 24/28 spokes to 85 KG
- 28/32 spokes to 90 KG
I am 72-74 kg and took 24/28. :smartass:
PostPosted: Wed Mar 20, 2013 11:55 am
PSM
how do you like this combination?
PostPosted: Wed Mar 20, 2013 12:58 pm
Actually, I haven't ridden them yet. Snow here in Stockholm since I bought them. But I am going to Majorca for a week on Saturday. Keed my fingers crossed!
Bought them for climbings... 8)
PostPosted: Wed Mar 20, 2013 1:06 pm
PSM
What weight they came about and what lace pattern you made front and rear?
PostPosted: Wed Mar 20, 2013 1:32 pm
1265 gr. One revolution rim tape. No Decals.
PostPosted: Wed Mar 20, 2013 1:55 pm
PSM
Have safe and great ride in Majorca, post some pictures from there!
PostPosted: Wed Mar 20, 2013 2:08 pm
I'll post a "RR" when back. ;)
PostPosted: Tue May 21, 2013 2:19 pm
I'm having Zen build me this wheelset 20 radial front, 28 2x rear. Sapim CXRays. I'm 72 kg, club rider, hill rider, occasional racer. The config was partially on Zen's recommendation and partially on a local builder who laced quite a number of 340 rims, but moved away from the area before he could build mine. Plus he favored DT240s which are great hubs, but a bit overpriced, IMHO. Two or three of the wheelsets this guy built have been through the Battenkill (all running tubeless I believe) with no problem. I understand the 2nd gen 340, if built correctly, can be quite durable. Battenkill certainly is a legit proving ground as far as that goes.
Anyway, wheels should be here in a few weeks, I can give a run down then. They're going on a '13 Tarmac.
PostPosted: Tue May 21, 2013 2:28 pm
i can tell for Kinlin rims 220 - wich are almost same weight - 370-390g and maby stiffnes also
24 front ;28 rear for 70-80kg rider.
24 rear is just for really light riders
and why not use round spokes 1,5mm front & NDS ; 1,8mm on DS? they are not aero wheels so there is no need for aero spokes.
http://kavitec.blogspot.com/
click this! http://www.youtube.com/watch?v=jqfFdCWAH5I&list=UUEtgd6K9EDGmoSE2YYipQgQ&index=20
PostPosted: Tue May 21, 2013 4:10 pm
The 340 rims aren't terrible for aero, and aero spokes will reduce the drag on any wheelset.
Also the XR200 is noticeably less stiff than the 340.
formerly rruff...
PostPosted: Tue May 21, 2013 10:59 pm
I built a similar set for a 175 lbs friend (24f/28r), but with the older Alpha 340 rim (lighter). The set came at around 1210g.
The rear wheel started creaking after 1000 km. We thought it was coming from the Mag 170 hub, but after lots of research, and help from Madcow, it came down to the tension decreasing on the Stan's rim. I re-tensioned the wheel last week. He didn't ride the wheel yet.
I don't know how stronger the new Alpha 340 rim is, but I'd recommend going a little stronger on the rear wheel for a 170 lbs rider.
Louis :)
http://www.ccsalma.com
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
Users browsing this forum: aaric, Google Adsense [Bot] and 7 guests
There are no new unread posts for this topic. Stan's ZTR Alpha 340 V2.0
Mackers
9
1520
Thu Jun 07, 2012 6:22 am
shadwell View the latest post
There are no new unread posts for this topic. Tires blowing off Stan's Alpha 340 rims
[ Go to page: 1, 2, 3, 4 ]
WMW
59
4768
Sun Nov 11, 2012 10:38 pm
spandexboy817 View the latest post
There are no new unread posts for this topic. Tune Mag 170 & Mig 70 with Alpha 340 's
nelson
14
1689
Tue Sep 04, 2012 12:22 pm
sjc166 View the latest post
There are no new unread posts for this topic. Industry Nine Ultralite XC + Stan's Race Gold 29er wheelset
944Turbo
Wed Mar 13, 2013 1:47 pm
944Turbo View the latest post
There are no new unread posts for this topic. Stan's tube sealant
sungerdds
Fri Oct 19, 2012 2:46 am
Getter View the latest post
It is currently Thu May 23, 2013 10:38 pm
