Post new topic Reply to topic  [ 5 posts ]
PostPosted: Fri Mar 08, 2013 1:10 pm
Hey guys;
I was wondering what the difference in rim between the Shamal and the Zonda is weight wise and what their actual weights are if anyone has (I've heard that the 2010 Zonda is 550g). I've noticed that the Shamal is toroidal milled whilst the Zonda is just milled. Could someone shed some light on this (the campy site isn't very good and searching didn't yield too much) and how much extra weight does toroidal milling save?
Apparently my bikes were talking the other day & are undecided whether to upgrade the current rider or get a new one...
one of the schemers...
PostPosted: Fri Mar 08, 2013 4:59 pm
What they are referring to is simply the tooling used to perform the milling. The three major cutters used in milling are flat bottomed end mills, ball nosed end mills, and toroidal end mill cutters. The tooling will NOT affect the weight in any way. What it can affect is the surface roughness and scallop height of the cuts. I propose that scallop heights are insignificant in this and really any application especially given the feed marks left in milling. This leaves surface roughness as the only variable that is affected by the tooling. Ball nosed end mills and toroidal end mills both generally produce roughly equivalent surface roughness measurements. Flat bottomed end mills will be much rougher -- but this is all relative and all three produce cuts that are pretty smooth to touch and sight.
This is probably way more than you wanted to know. In short, they are trying to make marketing claims based off of nothing.
PostPosted: Fri Mar 08, 2013 5:20 pm
the biggest differences between the wheels are that the shamal uses aluminum spokes, carbon hubs and ceramic ball bearings while the zonda uses stainless steel spokes, aluminum hubs and steel ball bearings. the weight diff is around 130 grams. 1440 - 1570. they are both great wheels.
PostPosted: Fri Mar 08, 2013 9:04 pm
I think Shamals are 1425g and my normal Zonda's about 1525g. Check the Campy website.
PostPosted: Sat Mar 09, 2013 3:08 am
Thanks dvincere, answers my question perfectly. Now to dig around for some rim weights
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. longer than normal eta?
fat tire
Tue Nov 06, 2012 5:07 am
elviento View the latest post
There are no new unread posts for this topic. Attachment(s) Litespeed Icon - are these welds normal?
alui
Fri Aug 10, 2012 1:40 am
There are no new unread posts for this topic. Shamal goes 'pop'
Lig
22
1706
Fri Nov 16, 2012 6:17 pm
Bigger Gear View the latest post
There are no new unread posts for this topic. Shamal, R-SYS SLR, SR11, etc
twigstim
Fri May 03, 2013 3:17 am
twigstim View the latest post
There are no new unread posts for this topic. Campagnolo SR Cassette: is this amount of wear normal?
incognitus
30
2271
Fri Oct 19, 2012 2:48 pm
DaveS View the latest post
It is currently Sat May 25, 2013 8:24 am
