It is currently Wed Jan 24, 2018 10:48 am
Post new topic  Reply to topic  [ 617 posts ]  Go to page Previous 119 20 21 22 2342 Next
PostPosted: Thu Aug 14, 2014 3:52 am
thechemist wrote:
Kayrehn wrote:
Sometimes the rubber casing gets in between the gap - try to pry ad widen the area around the stem first. If you're using a long stem for deeper rims, I'm amazed you managed to get the stans sealant in at all!
Well I haven't glued the tire back on yet so I will go check around the casing and make sure the stem is easy access.
I am using zipp 404s but once I took the value stem off I just put the sealant in the valve stem hole?
You can use a Maxxis MVS valve extender to replace the red Vittoria valve, they're interchangeble. Maxxis extender's core is removable, so it's easy to fill sealant.
PostPosted: Tue Sep 23, 2014 10:06 pm
Have I just screwed up royally?
I've just gone back to tubs. As part of the preparation I bought a light Tufo tub and some Tufo tape to carry as a spare under the saddle. Having read what I thought were references to pre-taped spares here, I applied the tape to the tyre, then folded it up.
Now watching. Youtube, it seems that the tape goes onto the rim. Does the tape really have a rim and a tyre side? If I'm just using it to get me home, does it make a difference?
And if I have to do a roadside change, it looks like I peel a small bit of tape cover off either side of the valve, mount the tyre, inflate it, *then* pull out the tape cover from between the tyre and the rim. Right?
I'm sure this is all fairly simple, but it doesn't seem simple right now...
PostPosted: Wed Sep 24, 2014 9:50 am
is the normal tub glued? if so, you just pre-glue the tufo spare, that's what i do, then when required you pull the flat off and fit the tufo, it should stick well enough to get home on (but i avoid heavy braking/hard cornering)
glue, let it dry, fold it basetape to basetape, secure with a rubber band and keep it in a ziploc bag/whatever to protect from rain/sweat/dirt
the glue will eventually lose tack, i reglue the spare every year or so
PostPosted: Wed Sep 24, 2014 12:07 pm
Greg66: I've been using an unglued spare with tape-glued tyres. The two or three times I had a flat, there was enough of the tacky stuff left on the rim to get me home with the unglued spare.
Yes, tape goes on the rim.
PostPosted: Wed Sep 24, 2014 2:25 pm
Ok, thanks. Sounds as if I've made a moderate horse's arse of it, but not so bad that I won't be able to get home on it. Which is all that matters. I can sort it out properly after that.
PostPosted: Wed Sep 24, 2014 6:17 pm
Tubbie Guru
Hi,
No, it doesn't but having the tape on the tub instead of the rim bed is just not that practical.
If you're current tub is simply glued on using rim cement I wouldn't bother with the Tufo tape on the spare.
If OTOH you already use Tufo tape on the current set up then good luck getting the tub off.....
Ciao, ;)
P.S. Two things I try hard to avoid when cycling: Tufo tape and Tufo tubs (I'd rather go see my dentist).... :mrgreen:
PostPosted: Wed Sep 24, 2014 10:40 pm
That's the price of being a newbie!
The wheels have a mismatched pair of tyres right now - a Conti 4000 and a Vittoria of some description. Both look to be glued.
The idea is to use the Tufo just to get home, then remove it and either repair or replace the punctured tub. The Tufo will back in the saddle bag for the next puncture.
Sounds like I should be able to make it home, at least.
PostPosted: Wed Sep 24, 2014 10:52 pm
Tubbie Guru
Hi,
I'd still peel off the Tufo tape from the spare and just pre-glue it with regular rim cement just the same.
Using the spare with the Tufo tape may make it pretty tough to remove it afterwards. Both tape and tyre that is.
Ciao, ;)
PostPosted: Tue Sep 30, 2014 10:50 pm
fdegrove wrote:
Hi,
Ciao, ;)
Took this advice. Tufo tape now securely screwed into a ball and in the bin. Phew!
Different question entirely: Zipp 404/808 FC tubs are wide: 26-27mm. What good tubular tyre comes in a width to match that?
PostPosted: Tue Sep 30, 2014 11:17 pm
Tubbie Guru
Hi,
The width of the Zipps is measured where exactly?
What matters is for making a choice of tubular tyre width is the width of the rim bed. I.e. say it measures 21mm then you can use a 21mm wide tyre and wider. never narrower than the measured width.
Ciao, ;)
PostPosted: Wed Oct 01, 2014 8:46 am
fdegrove wrote:
Hi,
Ciao, ;)
Good question. I was look here: http://zipp.com/wheels/808-firecrest---tubular/# under "Specs".
Brake Track Width (center) 26.04mm
Max Width 27.5mm
PostPosted: Wed Oct 01, 2014 1:53 pm
Tubbie Guru
Hi,
The specs would suggest anything as wide as 25mm and upwards.
Ciao, ;)
PostPosted: Sat Nov 08, 2014 4:38 pm
I've found that the adhesion for Tufo Tape is not nearly as good as Mastik glue. There is such a difference that I will continue to use Mastik.
PostPosted: Fri Nov 21, 2014 1:09 am
By the time my tubs with mastik 1 glue have set I cannpt remove with my hands alone. Levering the tub of with a tyre lever is the only way. Thats how good this glue is. A tub never moves with it. I have yet to find the spare tubs popped on at the road side moving either. The last spare I had to pop on I did in the end re glue after a few weeks but after having difficulty pulling the spare tub of I have to wonder why I bothered. Mastik1 is brilliant stuff.
I do put three layers of glue on the rim and a layer or two on the tub it seems to create a very firm bond.
www.thecycleclinic.co.uk
PostPosted: Wed Nov 26, 2014 4:46 am
Hi,
Having just converted myself into riding tubulars, I'm just curious what is the general consensus on measuring the life of a tubular tyre? Do you go by miles ridden, time (weeks, month, year..) or just by looking at the wear of the thread?
And if so, when is the time to change a new tubular?
There are no new unread posts for this topic. Chasing that elusive perfect transition to the hoods
jever98
Wed Aug 30, 2017 4:52 pm
vejnemojnen View the latest post
There are no new unread posts for this topic. Road disc wheels - making the jump, what should I get?
in Everything wheels
gerryc89
Tue Mar 28, 2017 12:43 am
jeffy View the latest post
There are no new unread posts for this topic. Help me get some tubulars
zalle
32
3018
Fri Mar 10, 2017 2:51 pm
Geoff View the latest post
There are no new unread posts for this topic. Want to try TUBULARS
53cxzero
22
1809
Tue Nov 28, 2017 1:10 am
53cxzero View the latest post
There are no new unread posts for this topic. open tubulars
bennybikes
Fri Nov 03, 2017 4:36 am
vanillaflyweight View the latest post
Users browsing this forum: Baidu [Spider], jlok, liam7020 and 5 guests
