It is currently Sat Dec 16, 2017 4:30 pm
Post new topic  Reply to topic  [ 541 posts ]  Go to page Previous 114 15 16 17 1837 Next
PostPosted: Sat Feb 15, 2014 10:28 pm
oh i see. sorry for the questions, is there a reason people prefer the 23mm over the 20mm?
PostPosted: Sun Feb 16, 2014 2:23 am
I moved to the 23mm wide HED C2's and really like them better on the century and double century rides. Personally I think that fast downhills are a little smoother on the 23mm's on our chip seal.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
PostPosted: Fri Feb 28, 2014 1:26 pm
jpac wrote:
What is the general consensus regarding the EDHub w/ Ceramic BB? Looking to buy a pair of the 2014 model, hoping to find out if its worth the extra to get these lighter hubs?
I only had one pair and they needed new bearings after 2-3 months. I realised it since there was suddenly some play in the back wheel. I bought a new wheelset a year later and switched to DTSwiss (still from farsports though)
PostPosted: Sat Mar 01, 2014 1:53 am
i've been riding my farsport 38mm for over a year now and the novatec hub (non-ceremic) is still quiet loud. anyway to make it quieter without affecting of overall roll?
PostPosted: Sat Mar 01, 2014 1:58 am
Take it apart and grease the freehub mechanism.
You can use Krytox (expensive, you can get it from Mcmaster-Carr) or good moly grease. It should not be sticky like wheel bearing grease or the pawls could stick, which could cause injury. You don't need a lot, just a little more than is on there now.
PostPosted: Sat Mar 01, 2014 3:57 am
Eric.. should I use a degreaser first to remove the original grease?
Sent from my SGH-M919 using Tapatalk
PostPosted: Sat Mar 01, 2014 9:25 am
In general mixing grease, oils ect is a no no.
PostPosted: Sat Mar 01, 2014 11:46 pm
I just wipe off the old stuff. The remains won't harm the new grease.
If you use a solvent on it then you have to make sure you get all the solvent out so it does not dilute the grease.
PostPosted: Sun Mar 02, 2014 1:23 pm
Administrator
This:
viewtopic.php?f=3&t=87659&p=1052014#p1052014
RESIDENT GRUMPY OLD MAN.
PostPosted: Tue Mar 25, 2014 6:42 am
Hi everyone. I've read the whole thread as I'm just about to place order on a 38mm clincher this coming weekend. Still not very clear on some items, as this threas started few years ago, and apparently new technology ha arrived to farsport, getting more confused on what will the perfect wheelset be for my needs:
1) i'm more a climber and my place is lots of mountains. Which rim width will suit me better? 20.5 or the new 23mm, or even the 25mm? I prefer weight reduction without performance penalty. I see more people switching from 20.5 to the other two wides.. Why?
2) not clear difference between the "new" u shape aero. How different it is from the v-shape? Will i need that for climbing?
3) bitex or edhubs? Don't want to pay extra money on what is listed.
Is there something else new in farsport that I shall consider?
Many thxs to all!
PostPosted: Tue Mar 25, 2014 6:44 am
Sorry for my gramatical mistakes/horrors, but my native lenguaje is spanish [THUMBS UP SIGN]
PostPosted: Tue Mar 25, 2014 8:55 pm
U shape is supposed to be less affected by side winds. When you climb you also have to descend and some times it's windy in the mountains.
My 50mm deep v shaped narrow rims can get blown around some. A few times in extreme winds it's been bad enough to make me slow down.
PostPosted: Tue Mar 25, 2014 10:46 pm
i have the v shape 38mm clincher from FarSport. the width as i recall from previous post was around 20.xxmm wide. i'm currently running with Michellin Pro4 service course for over a year now and riding true even through bumps and some small pot holes.
question... anyone here tried running it with a 700x20 or 700x21 tire? any pros and cons in doing so besides maybe less rubber contact with the road and harsher ride?
PostPosted: Wed Mar 26, 2014 12:46 am
The last time I tried a 20mm tire it rode like a rock and had traction like a rock: none. I like being able to corner.
PostPosted: Wed Mar 26, 2014 1:19 am
Thanks Eric... my wallet thanks you too... ;)
There are no new unread posts for this topic. Roval CLX 50 Clincher Rim Review
in Everything wheels
sethjs
Tue Oct 03, 2017 11:53 am
Beaver View the latest post
There are no new unread posts for this topic. Carbon-Ti hub review
madcow
Wed Mar 22, 2017 5:54 pm
madcow View the latest post
There are no new unread posts for this topic. Attachment(s) cheap and light carbon seatpost review
in MTB
02GF74
Sun Dec 10, 2017 5:20 pm
02GF74 View the latest post
There are no new unread posts for this topic. Thoughts on FarSports wheelsets
DavidMLee
Sat Jul 15, 2017 1:35 pm
F45 View the latest post
There are no new unread posts for this topic. Anyone used the Farsports FSL-20TM-23 t700c toray tubulars
dereksmalls
Mon Jul 31, 2017 3:30 am
dereksmalls View the latest post
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
