FarSports 38mm Carbon Clincher Review Thread, The
rijndael
by rijndael
adi13 wrote:I will be chossing the DT240 hub
I'd probably go DT240 too, but I was never too comfortable with the idea because I've heard there are knock-off DT240s around - I don't know how to spot them.
Juanmoretime
Administrator
by Juanmoretime
So what issues have people had with latex tubes? I received my 38mm 23mm wide carbon clinchers with the ED hubs. I used Stan's yellow tape, Michelin latex tubes with 4000S tires. I have yet to ride them between being sick, crappy weather and leaving on vacation in 2 days.
RESIDENT GRUMPY OLD MAN.
prendrefeu
by prendrefeu
Latex tubes will probably not be able to take the heat from extended braking.
You may be fine though... unless your area is pretty hilly?
MisterNoChain
by MisterNoChain
Next season i will ride with latex tubes on my carbon wheels. I've read a lot about it and as long as you dont go into the mountains it shouldnt be a problem. The biggest 'hill' in the area is 100m above sealevel, i dont expect to be overheating my rims on those decents :)
As said by prendrefeu i wouldnt be taking those into the mountains, better safe then sorry.
Juanmoretime
Administrator
by Juanmoretime
I live in the Midwest. I'm sure I'll be fine since the biggest climb I did on my road bike was less than 500' and generally no brakes needed or very limited.
petepeterson
by petepeterson
In my experience with farsports and challenge latex tubes the carbon clincher rim will fail before the latex tube does.
petepeterson
by petepeterson
The DT 240s from Farsports are legit. I have ordered two sets of wheels from them with these hubs and they are 100% authentic, star ratchet and all.
jpac
by jpac
What is the general consensus regarding the EDHub w/ Ceramic BB? Looking to buy a pair of the 2014 model, hoping to find out if its worth the extra to get these lighter hubs?
Slagter
by Slagter
jpac wrote:What is the general consensus regarding the EDHub w/ Ceramic BB? Looking to buy a pair of the 2014 model, hoping to find out if its worth the extra to get these lighter hubs?
People in this thread seem to be pretty satisfied with them...
jpac
by jpac
Nice thanks!
oreoboreo
by oreoboreo
I am in the same camp with ED CB hub. I ordered my second set a couple of days ago with the ED CB hub. I upgraded my first set to an 11 speed, while having them apart verified the Ceramic bearings.
You are in PDX and probably ride some of the same area that I do, you will enjoy them.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
jpac
by jpac
Nice, good to know. do you have the 38mm CC or the 50mm CC? and did you end up getting the U-shaped "aero" design?
oreoboreo
by oreoboreo
My first set is the 38mm x 20mm U shape. the new set is the same however 23mm
jpac
by jpac
i see, i wish i could go lower than 38mm, i weigh little to much to risk going to 23mm.
oreoboreo
by oreoboreo
Sorry, the new ones are 23mm wide.
